Question about Craftsman Drills
I have a Nextec 12V cordless drill, when i press the trigger, the light flashes, but, the drill does not work. i have tried different batteries and have changed the settings and switches and it still doesn't work. What now?
    New Friend:
At first it does sound like the batteries.
How old is the drill? If it's old, then the batteries may either be dead, or need a careful, slow charge overnight to charge them properly. If new, then they may also need a really nice slow charge.
Sorry to ask, but have you fully charged all the batteries you have tried? !!! Many rechargeables lose a great portion of their charge if they sit for a long time.
Also, when using the drill, never use it until it runs the battery down so far stops, as this can damage batteries or discharge them to where again you need to very carefully charge them to get full charge back again.
Have you overloaded the drill:any plastic smells or have you drilled too hard and stalled it for a long time? That could cause motor damage. But look to the batteries first.
Posted on Feb 22, 2011
6ya staff
SOURCE:
PBS 18 li-2 bosch cordless drill lights on but no power.
You are sure the battery is charged OK? Bosch Li-Ion drills have a feature whereby they stop working when the battery is low but not discharged right out. This is to extend the battery life as it does not like being flattened altogether.
This happens quite suddenly, from one press of the trigger to the next. It can make you think the drill is faulty.
If the battery charge is OK, then maybe
- trigger faulty
- motor burnout
- broken contact on battery or in drill battery shoe
Oct 28, 2014 | Drills
I have a Makita with 2 PA14 batteries and a DC1414F charger. When I turn the charger one the green light flashes once but no other lights show at all when I'm trying to charge my 2 batteries. Neither...
You stated you have a 12V Cordless Drill with PA14 batteries. The PA14 battery is 14.4V. The battery may fit in your tool and might work for a while but the motor isn't made for that battery. The way to check the batteries is to try them in another charger, any 14.4V to 18V pod/stick charger will work. The way to check the charger is to try another battery, any good 7.2v to 14.4V pod/stick battery will work. Unless the charger got wet or extremely hot the problem is usually the battery. Just check to make your tool and battery voltage is compatable.
Aug 08, 2010 | Makita 12 Volt Cordless Drill/Driver Kit
Dead DW972 Cordless Drill?
Easiest and safest: take the tool and batteries to nearest shop where they sell Dewalt. Ask the guy to let you use their batteries in your tool and vice versa, your batteries in their tool. DYI procedure:To check batteries: - if you have some multimeter, try to measure voltage and if possible also amps (but only for a fraction of the second, if battery is good, amperes shoudl jump up very quickly) - if you have no multimeter, try to find 12V bulb (check spare bulbs for your car), use wire to connect and it should light up. To check tool: open it up, take some 12V DC source, put wires on contacts inside the handle where battery connects. Pull the trigger and it should work. you can try to put wires directly to contacts on the motor. Follow cables from the switch to motor.
Juraj
May 31, 2010 | Dewalt 12V XRP Battery Pack
Dewalt cordless 12v drill, 3speed model...spinning problem
Sounds like your brushes are either damaged or the armature is failing the current. Remove the brushes first and inspect them, that is where your arcing is coming from. If the brushes appear ok, your problem is in the armature itself. Regardless of low use, if you store the unit with the battery attached, there are issues with the current draw while stored.
Jan 17, 2010 | Garden
DeWalt DW972 cordless drill has intermittent variable speed trigger. (Battery is fine, recently replaced) How can I clean the variable resistor in the trigger or must replace the whole trigger module?
have to replace whole trigger assembly.
worn brushes in the motor can also cause intermittent function, if you havent already checked those. i'd replace those first if they have never been replaced or look worn, broken, cracked, or if springs seem worn.
Dec 14, 2009 | Dewalt DC727KA 3/8" 12v Cordless...
I have a 12v xrp cordless drill. in the past 6 months i have purchase 3 new batteries. none will hold a charge. what is the problem.
You may want to try a different charger base. Any way you can borrow one so you don't have to purchase first?
If for some reason the charger isn't working well, you may be getting a partial charge and only that.
You may even want to rent a cordless just to try charging your own battery on a different base.
before you buy.
Nov 03, 2009 | Dewalt DC920KA Heavy Duty Xrp 18V Cordless...
12v drill/driver not holding charge
sounds like the batt as had its the same prob as i had with mine to give it a bit of life so it will charge get hold of a bigger batt and two bits of wire and connect the + to + and - to - and it should charge but it prob will run down quick
Mar 15, 2009 | Dewalt DC727KA 3/8" 12v Cordless...
Drills Logo
438 people viewed this question
Top Craftsman Drills Experts
John Trevino
Marvin
Marvin
Tom Chichester
Are you a Craftsman Drill Expert? Answer questions, earn points and help others
