Acer X193W LCD Monitor Logo
Posted on Feb 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DVi connector, In my CPU i dont have the slot for the DVi connector, where will i get the normal (vga) connection card. and whats that DVi connector means
Anonymous
Level 3:
Brigadier General:
  • Master 10,406 Answers
  • Posted on Feb 21, 2011
Anonymous
Master
Level 3:
Brigadier General:
Answers
10406
Questions
Helped
2557569
Points
31058
DVI ==> Digital Video Input
If your monitor has both DVI and VGA inputs,
and your PC's video-card has both DVI and VGA outputs,
then buy a DVI-to-DVI cable, and use it, for a better picture.
and your PC's video-card only has VGA output,
then use a VGA-to-VGA cable.
Or, purchase a video-card with DVI output,
to replace the video-card with VGA output,
and then use a DVI-to-DVI cable.
3answers
My PCs monitor shows no boot screens or desktop, on my hp pavilion desktop.
no PC just pavillion stated the case sides sticker HP clearly answer this question, called a service tag
the desktop makes fan sounds, turned on, does it?
2 fans or more, PSU and CPU
monitor tests good , and is not a bad vga cable, proved.
PC (unstated ) bad ok
if PC is bad, and monitor is turned on first
the monitor will show "no signal" or cables not connected or no sync)
(hint, monitor on first, count to 10 turn on PC last)
so test the PC ,oK, it is not hard,.
step 1, do both both fans spin and actually blow air
3 fans or more, with nicer video card with fan.
fan 1 , PSU
fan 2, CPU
fan3, GPU and even case fans exist,
12 steps, #1 is hard power reset.
last of after all is bad motherboard if VGA jack THERE is dead.
i bet it is not a bad mobo, ok.....
if you see 2 VGA jacks on rear of PC or DVI
only one will work, the one on the PCI VGA slot will be active only,so do not use the wrong JACK,]
oK?
I cant see your PC or guess which of vast models made this is, at all.
no monitor stated
no cable types stated,VGA/DVI/HDMI/DP????WHAT/?
NO PC STATED, LIKE PAVILION A6200 SERIES (OLD)
http://pcdied.com/dead-PC.html
why post lacking PC model.?
huge # of models, must be guess and guess wrong?
good luck, finding it , the tests are very easy,ask how.8676cba3-0a30-411d-a00f-a0e47c78e86f.jpgpav2-wo3xuzxrf1fbbh20dngovhzw-1-2.jpg8676cba3-0a30-411d-a00f-a0e47c78e86f.jpg
2answers
2nd monitor does not work with DVI to VGA converter cable. My video card has VGA and DVi ouputs.
The problem could be in the adapter to the video card. There are different types of DVI connections. If the adapter does not have the proper set of pins then the card will not recognize that a monitor is connected at that port. Monitors themselves have no bearing on whether a single or dual monitor set up will work or not. Digital Visual Interface Follow this link, it may help you determine if the adapter you are using is correct for the graphics card.
Alba 22 Inch monitor drivers
You need to explain your actual problem. What operating system, graphics card, PC, resolution required, monitor model number, connector type being used (VGA, DVI, HDMI) etc.
Monitors don't usually require drivers to work. Drivers for your graphics card may affect operation or you may be using the wrong lead/connector/interface.
2answers
I have an HP m9000z that was previously used with a DVI cable/monitor. I only have a VGA cable/monitor and the pc doesn't access the monitor.
This PC has a VGA and a DVI ports? Are both ports on the motherboard or a Video card? Or is the VGA onboard video and DVI is a Video card? You may have to disable the DVI port to get Video to vga or enable the vga port.
3helpful
3answers
I need to buy a new monitor. What kind of monitor will it support, GA, DVI, HDMI ? Thanks.
You should go for a Widescreen LCD ro LED monitor. They all support VGA and DVI. If you get a Full HD screen then it will have a HDMI connection also. Just make sure your Display card can handle it.
3answers
Montior 14 inch montior ligt on but not disply what is problem
Is the monitor DVI + VGA? blue and white ports (2)?
If so, you may need to hit the source button to switch sources. This can happen rarely.
Another option is to try a different monitor to verify that it is indeed your monitor that is broken.
Good luck! :)
Connectivity card from montior to CPU is different than other PCs, in back side of the monitor its showing to type VGA and other one DFid something, In my CPU i dont have the slot for the other type DFi, ...
I believe you are referring to a DVi connector. We have different types of connectors but none of them is DFi. We have VGA, HDMI, SATA, and DVi connectors. Here's a cheklist of what you need to do:
  1. Check the connector of the computer whether you have VGA, HDMI, SATA, or DVi
  2. Check the connector of the monitor whether you have VGA, HDMI, SATA, or DVi
  3. Now that you know the type of connectors you have for your system, you know what cable to buy.
It does not really matter if your computer and monitor have different connectors. We can purchase cables with VGA - VGA, HDMI - HDMI, DVi - DVi, VGA - HDMI, VGA - DVi, HDMI - DVi. So, don't worry and thank you for choosing FixYa!
2helpful
2answers
Hello! I have a processor intel pentium dual cpu e2160 @1.80 Ghz and for display a graphic card NVidia GeForce 7300SE/7200 GS, DAC Type Integrated RAMDAC 512 mb. I use my VGA monitor connected to the...
Hello ghinea18, sorry you can't do that because this will cause hardware conflict, that's why motherboard bios automatically disable integrated graphics if you install video card using pci express x16 slot - Nvidia GeForce 7300SE. do you know if your video card has dual vga or dual dvi connection?
You can try dual display, im not sure if this card supports dual monitors because nvidia online specs does not show full specs on 7300se series. \
Good Luck!
7helpful
5answers
Hi,how do I know wheather I need DVI or VGA cables to connect CPU to a Monitor.I sold monitor when I got laptop now I want set up the Dell Dimension 3100 as aback up,so I'm looking at wide sreen monitors...
Most of the Widescreen monitors come with DVI as well as VGA connector. A VGA connector and DVI connectors are different in many aspects. First of all the DVI connector would be white in color and VGA would be blue.
VGA connector has 15 pins and DVI has 24 +1 pin
4helpful
2answers
Monitor goes blank after showing XP logo screen (black screen with the xp logo right after boot up screens)
There are different reasons why this might happen. Let's try some. 1.) Does your board have an onboard video card, cause if it does, then XP might be using that as the primary monitor. TRy plugging into the onboard video when you start up! If that works then you need to disable the onboard video.(try disabling it in bios!) if not then 2.)When booting at the select xp or recovery console, press F8. You'll get the menu with safe mode and what not. Go down to Enable VGA Mode then press enter. If that works, go to display settings and lower your resolution then restart. But usually when this happens your monitor says "Out of Range" but u can still try Well if that doesn't work, tell me more! Regards, Armando
Steve Sweetleaf
Steve Sweetleaf
Grand Canyon Tech
Grand Canyon Tech
