Westinghouse LTV32W6HD 32 in. LCD Television Logo
Posted on Feb 21, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The color on my television is going in and out. Faces look like a shadow is moving accross them.
Veril Gillette
Level 3:
Genius:
  • Master 1,126 Answers
  • Posted on Feb 21, 2011
Veril Gillette
Master
Level 3:
Genius:
Answers
1126
Questions
0
Helped
212904
Points
3124
In sounds like the tuner might be going out, try to use the RCA, input connectors.
I have a 60 inch Mitsubishi and there are light red shadows in the tv. is this an easy fix
It sounds like you need to re-adjust your convergence. The purpose of adjusting your convergence is to align your red, green, and blue colors. Moving your TV often causes this problem. I hope you get it going.
Picture has ghost shadows in the faces of people mainly news anchors. Light colors like whites and oranges also have shadows. What could be causing this?
If it does not really display this when a DVD etc is played via a rear audio/video input it is not the set.
Modern cable or sat signals often are compressed and sets cannot on close up views keep up with the signal--when signal is compressed it causes this kind of issue--no way around it.
2answers
The skin tones on people's faces are different colors and shadowed and I can't find my owner's manual.
its ok, pause the screen and get a wax crayon the colour that you want the peoples faces to be and colour over them on the screen. when you have fully enjoyed that frame scrub it off and pause the video 1 second later. eventually you will make the whole movie like this the exact colour you want it.................
2helpful
2answers
Have a Vizio P42HDe purchased in 2005. Right half of screen is fine. Left half is series of small vertical bars (various colors). Sometimes they go away and all of screen is okay. Any ideas?
I bought mine in Jan 2005 and today it did the exact same thing....doesn't go away. Seems like a 5 yr. lifespan on these.
Will try a Panny for Christmas !!
mikebc580
Double pictures
Problem #1 - Failure in the convergence circuits. ( common problem )
Here are some of the most common symptoms and example photos of a convergence problem
  • Screen looks 3D
  • Colors don't line up
  • One or more colors can't be adjusted when using the convergence menu.
  • Screen is bowed or warped.
Here are some photos of convergence problems.
Here is a quick test....
Using your original remote go-to the tv settings then goto the convergence section.
Try to adjust the red and then the blue convergence.
You should be able to move them up, down, left, and right.
If you can't move them in all directions your convergence chips are bad and should be replaced. This is a common problem.
0667c5f.pngSOLUTION
You will need to replace the convergence chips and possibly some convergence resistors and pico fuses. Its a fairly easy DIY job or you can call in a pro. If you want to do the repair yourself check the site www.TvRepairKits.com. Their kits include a photo instruction guide, original OEM Sanyo STK chips, convergence resistors, pico fuses, thermal paste, email/phone support, etc.
I have a blue shadow outlining faces and pictures on my 50" is it color adjustment? how can I fix it - Please
No this is not a color adjustment sorry to say! it sounds like the circut board thet runs the color lenses inside your tv has some burnt out capciters and the circut board will need replaced! (the one thet controls the blue lens!) Please rate my response!
THANK YOIU!
Blue and Yellow Tint accross the screen ILO - 32HD
if you have speakers or a magnet or maybe an arial too close to your screen move them away. now try it. they can all interfere.
FINE TUNING tv PICTURE
try calling the Insignia help line at 877-467-4289
Top Westinghouse Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Westinghouse Televison and Video Expert? Answer questions, earn points and help others
