I hear that these firewire to usb connectors don't work for video transfer anyway.
You can get an add-on Firewire interface card that fits in a slot on the PC's expansion (PCI) bus. This will come with a driver for the card. You shouldn't need any driver for the camera. My camera (a Samsung) is controlled by the Windows Movie Maker program that came with Windows XP. This will cause the camera to rewind and play, and takes in the video to a file.
If your trying to connect a device via usb to your computer and it isn't being recognized; The best thing to do is go the manufacture's website of the device, look under download or support tab and download the latest version of the driver
The driver is what lets the computer recognize the device.
Download the driver, then double-click on the file so it will install itself on your computer. Once the driver is installed, restart pc, turn on your device and finally connect your cable
This type of camera usually downloads better with a Firewire (DV) connection. Some mini-DV cameras only use the USB connection (if they have one) for stills and can only download video by Firewire. This is because you have to play the tape into the computer, not just copy a file.
Most PCs have a USB port, but no Firewire port. Macs often have a Firewire port but may not have USB. As most Windows PCs do not come with this interface, you might need to fit an add-on Firewire interface card. This will come with a driver for the card.
Suitable Firewire (DV) cables can easily be found on Amazon or eBay. You will need the kind with a small (four pin) connector at one end and a larger (six pin) connector at the other.
You can download a manual for this camera by enterring the model number in this webpage.
This problem is sorted out, upon checking the handycam the USB streaming was not enabled, the same was enabled and my computer could recognise the device.
I believe that camera only works with firewire. You might want to check with Canon to see if there is compatibility problems with Macs. I know it works on Windows computers.
Firewire works fine under Vista, but it's quite possible your USB to Firewire bridge doesn't have proper Vista drivers. You wouldn't expect Vista to include these, they would be installed from a disc that came with your adaptor. USB to Firewire is a questionable option at best... there are often problems with it. You may be better off with a PC-Card or ExpressCard solution, if the laptop is your only computer.
Also, when the camera says "DV IN", it's expecting video from the PC to be sent to it, it's not in capture mode. Most camcorders must be in either "play" mode, or a special "link to PC" mode in order to even be recognized by Windows (any version) as a video input device.
However, until you resolve the issue of supporting your Firewire device in Vista, nothing the camcorder does will be an issue yet. You should check the documentation that came with your USB to Firewire device, the driver disc, etc. for information on Vista support.
