Question about Goodmans GTVL19W17HDF 19 in. LCD TV
Hi there, i have a GOODMANS GTVL19W17HD MONITOR and its connected too my computer, and my problem is when ever the computer loads at startup the monitor turns of and then turns on with weird colours and then goes back too normal and also im running windows vista could that be a problem? when the windows vista boot screen comes up the icons are in the top right and they are flickering i done understand what is going on with it, it goes back too normal when windows has fully started up. i have already tried too change the HERTZ they were on 60 and i changed too 75HERTS MY screen resolution is 1024 by 768 pixels would that be any problem? PLEASE HELP WITH THIS IT IS SOO ANNOYING.
    Sergeant:
  • 248 Answers
Power off monitor until the computer has booted.
Posted on Apr 01, 2017
4 Suggested Answers
6ya staff
SOURCE:
Eugene Merritt
  • 298 Answers
SOURCE: Olevia LT23HVX screen resolution
It says 1024X 768 s in pc mode are you connecting
in tv mode or pc mode
Posted on Nov 29, 2007
specialistel
  • 8909 Answers
SOURCE: why is resolution 1024 X
1024 X 768 was known as "The Sony Standard" in PC format. 1365 X 768 is slightly wider screen size, that is all.
Posted on Dec 19, 2010
Jeff Pogi
Jefferson Tope
  • 62 Answers
SOURCE: hello there, today i connected my goodsman
Turn on your computer...while booting press F8 then select SAFE MODE..press enter. Now, you must adjust your video resolution found in graphics properties. adjust the resolution in minimal only then restart your pc. thats all...it will back to normal
Posted on Feb 22, 2011
Testimonial: "thank you for this i havent tried it yet but i will try and let you know, i have the rating because you were the first one to reply. :)"
Running watts and startup watts
On the compressor will be FLA, full load amps, starting, and RLA , run load amps, running amps.
Nov 27, 2013 | Goodman Heating & Cooling
Hi there, i have a goodmans GTVL19W17HD T.V connected to my computer and and the back of it there are VGA AND HDMI connectors and my graphics card has a vga but it doesnt have a HDMI Connector, but if i...
VGA quality only. If you want to release the high definition features of your TV, use high definition
graphics card together with HDMI cable. Hope it helps. Good day!
Sep 02, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
Hi there, i was just wondering that, my hdmi monitor which is goodmans GTVL19W17HD monitor and it has a HDMI slot, but my graphics card doesnt, instead my graphics card has a vga and dvi slot, and if i...
Hi hassy786,
Regarding your question if you will use a converter from VGA to HDMI will it provid High Defenition video?
I believe that it will provdie video converting the signal from VGA to an HDMI connection but I do not think that the video will be High Definition since the VGA is just being converted to HDMI signal and not an actual HDMI but just a converted signal, and it is possible that it may not work properly or the LCD TV may have difficulties recognizing the signal from VGA converted to HDMI.
Thanks for chosing Fixya,
avf110686
Mar 27, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
Hello there, today i connected my goodsman GTVL19W17HD monitor too my computer which has a VGA port on it and so does the goodsman monitor, and i have got windows vista running, but when i turn the...
Feb 22, 2011 | Goodmans GTVL19W17HDF 19 in. LCD TV
My X-2gen monitor turns white upon startup.
You may have failed T-CON board (part of the LCD panel), bad connection on the ribbon cable between the LCD panel and the logic board, no 5vdc feeding the T-CON board. Need to do soem checking.
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Jul 04, 2010 | X2Gen MG17J 17" Monitor
I cannot tune my goodmans gtvl19w17hd tv
If you have sound, then your tv doesn't need tuning. Shine a bright light onto the screen, can you see a very dim picture? If so, your backlight has stopped working. This is almost always due to the inverters failing and can be repaired.
Jan 26, 2010 | Goodmans GTVL19W17HDF 19 in. LCD TV
SKY REMOTE CODE FOR GOODMANS GTVL19W17HD
The remote code is 1130 for this set.........using a v8 remote for HD box..... took 3 attempts to get it to work..... hope this helps....
Oct 12, 2008 | Televison & Video
Input not supported
You may have a video resolution selected on your computer that the screen doesn't support.
The reason you see the the initial startup message is because that is loaded from the bios, prior to the settings for the graphic card output being loaded.
Try booting the computer in safe mode and adjusting the display resolution.
Dec 29, 2007 | Acer AL1916W 19" LCD Monitor
Goodmans GTVL19W17HDF 19 in. LCD TV Logo
97 people viewed this question
Top Goodmans Televison & Video Experts
Ekse
Colin Stickland
Colin Stickland
martin hogg
Are you a Goodmans Televison and Video Expert? Answer questions, earn points and help others
