Konica Minolta bizhub C250 All-In-One Laser Printer Logo
A
Anonymous Posted on Feb 22, 2011
How much is a fuser unit for a bizhub 250? I got a c3451 error.
Anonymous
Level 2:
New Friend:
  • Expert 60 Answers
  • Posted on Feb 24, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
60
Questions
0
Helped
34822
Points
107
Around 250-280 $ (include shipping) but you may need a technician to clear counters, reset error code, and install and test the new fuser. If you want to do it by yourself, may be time consuming.....
1helpful
Error c3451 for bizhub c450
Error c3451: "Heating roller warm-up failure"
Malfunction c3451 detected for bizhub 250 konica minolta
Try this It could do the trick for you.
The error code c3451 refers to a copier warm up error; the machine had not reached the correct temp within a specific time.
I bet it happened when you first switched on one morning.
Easy to reset and fault usually goes away.
To Reset switch machine off using the switch inside the front door, not the one on the control panel.
Whilst holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen, touch this, OK will be displayed then power the machine off and then back on.
This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing.
Read More...
Error Message C3451 and Printer Support and Konica Printer Support
How to reset error c3451 in konika minolta 215
clear/stop held down and turn the machine on, IF THIS CODE COMES BACK DO NOT RESET AGAIN IT IS POINTING TO FUSER UNIT IT CAN CATCH ON FIRE GET TECH OUT AND REPLACE THE FUSER
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Error c3451
Fuser not getting warm enough, first check if there is paper wrapped around the upper fuser roller, if so remove it and reboot the machine.
If this is not your problem then your thermistor inside the fuser unit needs to be replaced
I get a code c3451
C 3451 and C 3452 Fusing warm up malfuntion.Verify the fuser unit and clean the thermistors and the thermofuses and try reset the error code.For reset press following keys:
Utility - Meter count - Details - Stop - 0- Stop - 0 - 1
introduction 0-0-0-0-0-0-0-0 press enter and select the trouble reset(counter windows).
I have a bizhub 250 and i am getting am error code c3451 i have tried the reset with the utility counter and also by hitting the number 3 after poushing the black button that is on the right side none of...
reset code is 00000000 is default if the code come back replace the fuser unit the HOT PART keep reset can cause a fire that will ruin a perfectly good day!!!!
4helpful
Bizhub 250 All-In-One Laser Printer: Error code C3451 wont reset using Utility key at s...
• The Fusing Roller Thermistor does not detect
the required temperature within 30 sec. after a
warmup cycle has begun; therefore, the copier
does not complete the warm-up cycle.
• The temperature of the Fusing Rollers does not
reach the required level even after the set period
of time has elapsed during a warm-up cycle.
You may have a bad fuser section. Another reset method is a small button located on the right side of the machine under on the scanner section. Locate your network port, then to the left of the port is a small cover that can be removed, behind that cover on the left is a small black button, use a paper clip or ball point pen and press the button, this will do a machine reset. When the operation panel abort starts to load hit the number 3 button, you should see a small back circle in the top right of the operation panel. This will give you the option to do a trouble reset.
If this does not work you will need a technician to come out and replace the fuser section, make sure they bring one with them so they don't have to reschedule and come back.
4helpful
Error c3451
this is a fuser temperature too low error code could be the thermistor or heat lamp is not comming on to reset the error code turn the main switch off the main switch is located on the left side opf the machine towards the rear and while holding the utility/counter button down turn the switch on hold the utility /counter button down until trouble reset appears on the touchscreen then release theutility button and touch the trouble reset button then turn the main switch back off and wait at least 10 seconds then turn it back on if the error code comes back have the fuser unit replaced
6helpful
2answers
Error c3451
First ignore the revious solution, it is not even close. The error code c3451 refers to a copier warm up error, the machine had not reached the correct temp within a specific time. I bet it happened when you first swiched on one morning. Easy to reset and fault usually goes away.
hope this helps
2helpful
3answers
Error message C4551 anyone? pretty please.
C3451: Heat. Heater Trouble
You have to check machine fuser unit .
May be paper on the fuser unit. Check fuser unit rollers.
After check fuser unit you have to ececute a "trouble reset".
Turn on your machine by press and hold "utility counter" botton, after some seconds press to display "TROUBLE RESET" and turn off and on machine.
C4551: Cyan laser Malfunction
Check cyan laser connection and execute trouble reset.
Bye.
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
