After a couple hours of operation the screen turns green and I ned to shut it off and turn it back on for normal operation and the frequency of this occurance is increasing.
See page 18 of the saltwater instruction guide ... 93 means it is on stand-by, power saving mode. Nothing is wrong, it's just waiting for the timer to tell it to turn back on automatically. If you want the system to be on right now, just turn the power switch off, wait a couple seconds and turn it back on.
My sony 65Ws500 model about 4 months ago it started turning the screen all blue as soon as I turned it on. it stayed blue for about an hour then come back on normal now when I turn it on it will shut down and I get a small red light flashing 8 time then pauses and does it again 8 time then pauses then again and so on. I took back panel off. I turn on tv The blue bulb gets very bright and the green and red projection bulb goes out and now it shuts off. and the blinking starts it a code flashing but don't know the code to find out whats wrong. would someone help if u can been wife and I laid off from work 3 months now cant afford tech prices on our employment. wife and I has 2 little girls to raise. along with the rest of u parent out there and one getting employment cant offord repairs. Thank U. [email protected]
Time to get a new TV. I have similar problem. In my case, the set turns off, LED blinking green for about a minute or 2, then the set will turn on by itself. Something the LED started to blink yellow after blinking green and then shuts off. I can turn it back on. This happens 3 or 4 times in an hour. After that, the TV stays on for as many hours as I want until I shut it off.
And then the problem repeats everytime I turn it on from a cold start.
I have my eyes on the 50 inch Plasma from Panasonic. Bestbuy has one for 999.99.
check capacitors, make sure the condensor coil is clean. sounds like the compressor is overheating. is the condensor fan motor still turning when it stops cooling. if not check low voltage wires to condensor, furnace and t-stat
My TV did the same thing for a couple of years. It is the precursor to the capasitor going out on the DM board. The good thing is that the capacitors only cost around 4 dollars if you can soldier them yourself.
I have never worked on a Mitsubishi with this problem but I have seen it in other sets. Most notably Zenith sets from about the same time. The Zenith sets have an electrolytic capacitor which fails (changes value) and causes the power supply to switch at a lower frequency. If the frequency is low enough the set will never turn on but if it is not less than half the operating frequency the set may turn on sometimes and run forever or not. It sounds like your Mitsu has a similar problem. This would not be an expensive fix but probably is beyond your expertise.
