Not sure if my TV was hit by lighting?? We had a small storm last night w/lighting. This morning when we turned on the TV it came on and stays on BUT the picture was on for only a split second, then the screen goes off as if your turned the TV off, but the power indicator light is still on. There is no sound after the picture goes off. Could the lighting have hurt it or is there another problem? TV is about 6 yrs old. Thank you for you help.
  • 2,794 Answers
It could be a blown fuse in the back of the tv. Check all the fuses behind the cabinet.
Posted on Jul 27, 2008
6ya staff
SOURCE:
Samsung LCD TV (Model UN65FH6001F) doesn't turn on? I have added more details in the below section.
There may have ben a power surge that caused an internal fuse to open. The power supply could have been affected as well.
May 15, 2018 | Samsung Televison & Video
My set is plugged into a cable box. the tv will not turn on either manually or with the remote.
Plug the power cord directly into a wall power outlet, and make sure that the standby light is lit (turn it on/off manually to see if anything changes). If there isn't any light, then it's most likely broken.
If the TV works again, being plugged into the power outlet in the wall, then the problem is with the cable box (i bet you figured that out too).
Jul 06, 2014 | Envision L32W761 32 in. LCD TV
Toshiba 42" hdtv just quit
chec the power point with another electrical item... perhaps the plug has triped.. if ok i think it will be your main fuse inside the tv
Jun 22, 2013 | Televison & Video
Why lights won't turn off after a lightning storm last night?
The light switch is defective replacing the switch should solve the issue.
Aug 09, 2012 | Televison & Video
My LG LCD 32LD350 seemed to have been fried in a storm last night, stanby red light no longer lit and won't turn on, still see some green lighting inside televison, but it won't turn on, Is it
Is it repairable, well, this question can be answered only after opening the back cover and evaluating the damage. From you side, please connect the TV to a different power outlet where other similar devices are working and see. Then try changing the input device to something that sure works. If it does not work even then, this may need attention by a qualified service technician.
Jul 27, 2012 | LG 32LD350 32 in. LCD TV
We had a lightning storm last night. The tv was working after the storm and was left on all night . This morning all that was on was the VIZIO light on the front and it will go off and on with the remote....
Sadly, only testing of each component can suggest the extent of damage. Many years ago, lighting can in through the window of my living room, hit the TV, blew the knobs off the TV (that date's me), shot into the kitchen and shattered the kitchen counter top. What I want you to take from that is that the course of a power surge is a bit unpredictable. No one can guess how far it got until you find a lamp that works.
Jun 14, 2017 | Vizio VO47L 47 in. LCD TV
My Vip622 was down this morning, no power outage,
Unplug the unit from the mains for at least an hour, then plug it back in again and try to boot it up.
Good luck
Jun 19, 2009 | DISH Network ViP622 DVR DTV Receiver /...
Post Storm Problem
Hope is last to dye. Be calm and contact the technician with best references or Authorized Sony Service. If you need more info please advice
Apr 12, 2007 | Sony FD Trinitron WEGA XBRKV-40XBR800 40"...
Blank screen
Similar monitor, similar problem. I actually had to dismantle the thing and replace a transistor on the mainboard.
If you're not into soldering and such, good luck.
Oct 03, 2006 | Mag Innovision LT776s 17" LCD Monitor
Televison & Video Logo
80 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
