Samsung Galaxy Tab Tablet PC Logo
Anonymous Posted on Feb 23, 2011
Is skype for the galaxy tabo only works as voice calls? no video calling?
Anonymous
Level 1:
  • Contributor 277 Answers
  • Posted on Mar 01, 2011
Anonymous
Contributor
Level 1:
Answers
277
Questions
Helped
93596
Points
43
Not yet. Use Google Talk instead.
  • Anonymous Mar 01, 2011
    I should have noted that Google Talk doesn't have video support for most versions of Android yet either. I think only Gingerbread and Honeycomb have video chat capability.
Any solution why I can't received any calls in XPOD phablet.
How to fix Samsung Galaxy S4 that can't receive text ...
thedroidguy.com/.../how-to-fix-samsung-galaxy-s4-that-cant-receive-tex...
Aug 14, 2015 - A phone that can't get signal can't send/receive text messages and make/receive phone calls. In this step, try to see if the phone is getting a ...Missing: xpod ‎phablet
Getting started with Skype (Android tablets) - Skype Support
https://support.skype.com/.../getting-started-with-skype-android-ta...
SkypeWith Skype for Android tablet, you can make free voice calls and video calls, ... With this option enabled, you don't have to tap any buttons to answer incoming calls. ... a replacement for your telephone and can't be used for emergency calling.
how to make skype video call of xpod tablet pc - howdroid.net
howdroid.net/q/how-to-make-skype-video-call-of-xpod-tablet-pc.html
How to make Skype video calls on Android using Fring ... With either, we can make andreceive Skype calls, but we cannot see the other person. ... but yet can't figure out how to make a video call, I can't see this option anywhere, any idea?
What service does phablet take? We got a art sim card and used a straight talk card but we can't reset and save new network info. Only my phone works and can't receive pics or internet. I can access f
You need to use a service that supplies data. Voice only will work to make voice calls, but won't have a data plan associated with it. Data only plans will work, after a fashion, but you would need to use Skype to make voice calls...
So a voice+data plan assigned to a SIM is what you need to use a phablet properly.
I just brought a he Sharper Image M18A" Tablet. Can anyone tell me if you can use Skype - as in see the other person. I know it's to do with the cameras on the tablet but when I brought this I wa
If you don't see the person you are chatting with on Skype, the issue is probably on their hardware. You do need to "Enable Video Call" from the Skype app's Menu after initiating a video call. If you aren't seen on the other party's side of the call, then it's your device settings that must be adjusted.
Does your tablet have a front-facing camera and Android version 2.3 or better? (The M18A is listed as having Android 4.0) If so, then you should be able to video chat with the Skype app. When you use the rear-facing camera, obviously there are issues with the other party seeing you.
If you have a front-facing camera, make sure that this is the default camera while the Skype app is closed. Open the default camera app and tap the icon to toggle the front camera interface (if needed). Then switch to video mode. Return to the home screen and open the Skype app. Login and start a video call. Then press Menu (in the app) and "Enable Video Call".
If this doesn't work, you may need the IP Webcam app. This is available at the Play Store. After setting the default camera, set the resolution and the frame capture rate, among other settings. Next, follow the directions for using Skype for a video call.
I hope this helps.
2helpful
3answers
I just bought a samsung galaxy tablet and i do not know how to set up the web cam on it. I also have skype installed on my tablet and for some reason i am not seeing a video call button when i click on my...
Hi! First of all in user's guide manual says that this tablet works just fine with only 3 IM : 1.Google Talk; 2. Windows Live Messanger 3. Yahoo! Messanger. Try one of those to see if the camera button appears.
However, if you need more information you can find them here: ( http://www.userguidemanual.com/samsung-galaxy-tab-gt-p1000-tablet-manual-user-guide-french-english/ ). *This link allouds you to read and download free user's guide manual (in PDF format).
I hope this will work! Have a nice day!
Hi. My samsung tab doesnt accept skype video call. I have samsung galaxy 1000. I am live in Serbia. Thank you
Make sure that you are using the most recent firmware version. If you have the 7" Galaxy Tab, then 2.3 would be the most recent version. If it's the new 10" version then Honeycomb 3.1 would be the newest. The firmware update fixes some of the issues with Skype.
Also make sure that your version of Skype is the most recent from the marketplace.
1helpful
How to used my camera for video call? Because if i used it my friend cannot see me on cam by using video call.
Checkout this site on how to get it to work.
http://www.samsunggalaxysforum.com/samsung-galaxy-s-how-to/how-to-make-video-call/
Skype downloaded on my galaxy tab but it does not allow me to sign in. I have uninstalled and re-installed and same thing. Skype does not seem to work. When it did work, it did not give me video...
You should be downloading the application from the Android market. It may not be the application, but the tablet that will not allow video capabilities. Try to re-install Skype then restart your tablet.
6helpful
2answers
Can i use the camera on front as a web cam to video chat within gmail? Or sykpe?
Gmail and skype do not have the ability of utilizing the front facing camera yet. Tango and Fring are both free options in the Android Market.
How to get the video to work on skpe
You can use yahoo messenger or fring or qik skype does not support video calling
Im on skype but no active visual just a frozen picture
Were you aware that the Skype app for Android doesn't do video calling as yet? If you are trying to do a video call, that would be why it is not working.
If the whole app appears as a frozen image it has probably crashed. Try pressing the home button to quit out and then kill the app and try again. If it still happens, try uninstalling and reinstalling.
Hope this helps, Alistair
Top Samsung Tablets & eReaders Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you a Samsung Tablet and eReader Expert? Answer questions, earn points and help others
