Good morning!
I believe that this is what you're looking for:
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Good luck & best regards,
Pelu.
Fix by an expert required such as www.SaveMyUSB.com
1. Faulty USB port on PC: Try a different computer or laptop
2. Faulty USB cable: Try a different Cable
3. Corrupt memory: Fix by an expert required such as www.SaveMyUSB.com
4. Faulty connections on main circuit inside the hard drive: Physical Fix by an expert required such as www.SaveMyUSB.com
5. Faulty controller chip (worst case scenario) : Direct flash memory read required by an expert required such as www.SaveMyUSB.com
Hope this helps and that it is 1 or 2 as 3, 4 and 5 will cost you money.
Good luck
Sorry about the delay with a replay
I am color blind so I have to waight for my daughter to help me on sunday
thank you and I will keep you informed of progress
Hello there, I do thank you for your prompt reply
However, My travel drive is 8 GB
Inside it is marked SEAGATE 8 GB ST1.2 Drive
And the four wires are:
Green
Red
Blue
Copper color
Hope this is helpful
Kind regards
Chob
Hello
Thank you again for your help.
I did connect the wires together but nothing happened, so I may think that the drive is damaged also.
But thank you for your helpanyway
Kind regards
Chob
