I am using Intel Gigabyte GA-8IDX 845 AGPset motherboard with intel pentium(R) 4 CPU 1.80GHz, with win xp O.S.
bios version is 2.05.13.03
now i am facing the problem with CMOS settings.i cannot change CMOS settings, few options are unchangeable like cannot change boot sequence.
in CMOS Setup Utility, Advanced BIOS Feautures, First Boot Drive is HDD-0 so i can not boot from floppy.
Try this.
Open case somewhere on motherboard will be (reset BIOS) or word to that effect. it will be a small 2 pin connector with a jumper on 1 pin connect the jumper across both pins for 30 seconds remove jumper fit back over 1 pin (not get lost) reboot your BIOS should have reset to default hope this helps post comment if does please
I dont found but i get battry off
tanx you collieweb.
