Question about Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune MDE9700AYW
The drum on our Neptune dryer has cracked and while we've received a new replacement drum (the second one since the first was warped), we have no instructions on how to install it. To get anyone out to do the work is prohibitively expensive.
  • bodiewidder Oct 07, 2008
    This was the procedure my husband ended up using (even before we got this tip) and all is working perfectly! Great advice!
  • Anonymous Nov 05, 2008
    How do you remove the drum on MDE9700AYW
    New Friend:
Where did you order the felt drum liner. It does not seem to be easily available online or from Maytag.
Posted on Feb 07, 2016
I AM IN THE PROCESS OF REPLACING THE DRUM ALSO BECAUSE OF IT BEING BROKEN RIGHT WHERE THE GROOVE IS IN THE BACK OF THE DRUM THAT RIDES ON THE ROLLERS.
HERE IS THE WAY I AM APPROACHING IT: THE OLD DRUM IS OUT - NOW I AM INSPECTING THE DRUM SEALS AND ROLLERS - SINCE THE OLD DRUM IS ALREADY OUT YOU CAN SAVE YOURSELF ALOT OF HEADACHES BY REPLACING THE DRUM ROLLERS, FRONT AND REAR DRUM SEALS, AND THE BELT ALONG WITH THE NEW DRUM. I WOULD ALSO TAKE ADVANTAGE OF THE OPEN SPACE TO GIVE THE DRYER A GOOD CLEANING AND VACCUUM PRIOR TO THE NEW DRUM INSTALLATION. BE SURE NOT TO FOLD THE REAR SEAL OF THE DRUM DURING RE-INSTALLATION. TAKE YOUR TIME AND DOUBLE CHECK EVERYTHING AS YOU GO MAKING SURE THE DRUM RIDES NICE AND SMOOTH ON THE ROLLERS AND THE SEALS ARE FLAT ALL THE WAY AROUND. I HOPE THIS HELPS YOU TO NOT HAVE ANY FURTHER PROBLEMS FOLLOWING YOUR NEW DRUM INSTALLATION.
JIM - MR MACHINE DOCTOR
Posted on Oct 04, 2008
We have the same machine. The drum also broke so we had it professionally installed. It wasn't done well enough and after the 90 day repair warranty, other problems developed. We still don't have a dryer and the next repair is $500 as other parts were damaged and we didn't catch it within the 90 days.
Bottom line: do have it professionally installed but be sure to ask about their work guarantee. As soon as you have any problem at all, call them back.
Posted on Aug 12, 2008
6ya staff
SOURCE:
Maytag neptune dryer model mde9700ayw rear drum felt is off ,making the drom loose.cant find replacement felt online
you can purchase new felt from most appliance parts suppliers , in your area that handles the Maytag devices.
Oct 28, 2012 | Maytag Dryers
My maytag epic dryer thumps with every rotation.has done this since it was first installed. service man tells me this is normal and cannot be fixed.
I had this problem and it turned out my drum was cracked. Look for a crack or unevenness in the drum. You may need to replace it.
Sep 03, 2011 | Maytag MDE9700AYW Neptune 174 Electric...
Is there something else i can use to replace the felt seal without buying a whole new drum on a maytag neptune model MDE9700AYW
On older maytag dryer's the felt seal wasa seperate part and not part of the drum..the problem is i do not know if the drum on the newer and older dryers is the same diameter they look similar in size but if it isn't exactly right may leave a gap where the clothes will get caught in...however the part number for that seperate felt seal is 314820
Gene
Aug 24, 2011 | Maytag Neptune MDE5500AY Electric Dryer
My mde9700ayw the drum cracked, i need to replace. the back ordered parts. first was 7-10 days, and now they say a month
if its back ordered your at the mercy of the factory. They will ship when they have it. Sorry Nothing you can do but wait
Nov 07, 2009 | Maytag Neptune MDE5500AY Electric Dryer
Maytag Neptune Electric Dryer Broken Drum
look in your owners manuel and see if the drum is covered.
Jun 23, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag Neptune MDE9700AYW Elec. Dryer. Drum Not Turning
the problem is with its motherboard .. i too had the same problem.. ask the repairing persons to change the motherboard if it is warranted. ( but there is no other way)..
Apr 21, 2009 | Maytag MDE9700AYW Neptune 174 Electric...
Maytag frontload dryer MDE9700AYW
take the door off. take the front panel off. take the belt off the tumbler. take the tumbler out. you should see the roller. everything is held with regular phillips head screws.
Nov 10, 2007 | Maytag MDE9700AYM Electric Dryer
Maytag Neptune MDE5500AY Electric Dryer Logo
475 people viewed this question
Top Maytag Dryers Experts
Marvin
Marvin
Gerry Harvey
Gerry Harvey
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
