Maytag Neptune MAH5500B Front Load Washer Logo
Posted on Feb 24, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My Maytag Neptune washer, model MAH5500BWW, had a burning smell during/after a wash cycle. I didn't notice until wash was complete. I turned off electric to the laundry and unplugged the machine.
John Tripp
Level 3:
  • Maytag Master 4,656 Answers
  • Posted on Feb 24, 2011
John Tripp
Maytag Master
Level 3:
Answers
4656
Questions
Helped
1677770
Points
14883
If you need help please contact me here=> [email protected] Thanks, for Understanding.... Sea Breeze The manual is 156 pages and Maytag wil;l not let me post here. Let me know, Thanks, Sea Breeze
Maytag neptune MAH5500BWW front loader didn't drain after a wash cycle. first time wife put it on spin for a few minutes and it drained, no problem. A week later that didn't work, code...
Yes you need a new control board. The fact that the motor and impeller was damaged and loosened. You should try taking your Washer in for maintenance check or call the repair man.
I have a neptune front loader, after the wash cycle is complete the clothes smell like they have not even been wash with a **** moldy smell. I use Tide HE as directed but they still smell like i...
Hello, Thank You for using FixYa. I will be helping you today.Try 2 cups of white vinegar on a heavy duty cycle with hot water.Pour it in the detergent dispenser after it starts to fill. Also the affresh tablets work good i would use 3 tablets at one time if your unit is as bad as you say.
Thank You and please rate my answer if it was helpful..
1helpful
I have a Maytag Neptune model # MAH5500BWW. It appears that there is still water inside the tub after completing a wash cycle. I only noticed it as I tried to get a stuck sock from the top of the tub and...
the noise you're describing is normal - there is water in a sealed balance ring on the inner tub. To get rid of the mildew and smell, leave door open after cycle and use something like Affresh or "Smelly washer" stuff monthly or more often.
Vlad,
First Choice Appliance
Maytag Neptune MAH5500BWW burn smell (doesn't appear to be hose)
if you have a maytag neptune washer that ran up until now you got your money's worth,that's the machine that put maytag out of business,if it's smoking and ripping the boot it sounds like the tub bearing is gone and you'll have to replace the washer,if it's load in the spin like marbles are rolling around in it that's the problem,but i wouldn't put a cent into that machine.
MAYTAG NEPTUNE FRONT LOAD WASHER MAH5500BWW
Central bearing and seal are damaged. Very expensive repair and very expensive parts. Maytag does not sell bearings separately, they're only available with the outer tub, which is $400-$500; Repair itself is another 2-3 hours of hard work. Do the math...
Very loud final spin cycle with burning rubber smell
Hi Mcbride2
It could be one of 2 things. 1 the belt. or 2 the main seal and bearing. i recomnd to get a tech just to make suer.
brent
1helpful
Maytag Atlantis shut down during rinse cycle.
Contacted a local repair shop. They told me that if I got it spinning again, the motor was most likely ok. It is protected by a thermal switch that turns it off when it begins to overheat. The smell was to be expected as it was overheating; the difficutly restarting was because it hadn't cooled off enough yet. We have now used it a few times for small loads. Still getting a smell, but the wash cycle is completing ok.
Top Maytag Washing Machines Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
ZJ Limited
ZJ Limited
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
