ASUS P5PE-VM Motherboard Logo
Posted on Feb 24, 2011
No displa - ASUS P5PE-VM Motherboard
Anonymous
Level 1:
Problem Solver:
  • Contributor 17 Answers
  • Posted on Oct 22, 2011
Anonymous
Contributor
Level 1:
Problem Solver:
Answers
17
Questions
Helped
7992
Points
17
Try to power your board first see if the HDD light blicks .... if not turn off your computer remove your mem card clean the brass connector for your mem card using a pencil eraser and clean the mem card seats on the board using a brush then re-seat your mem card ... if stil not working replace your mem card with known good mem card if its ok replace your mem card
if theHDD light blink and no display check your video card clean your video card from dust build ups and also clean the brass connector using pencil eraser clean also the video card seat using a brush if your video card doesn't work have it replace
if your using a built in video card use an add on video card
regards
eric
  • Anonymous Oct 22, 2011
    if non of this solution work then you got a problem with the board common cause is a toasted capacitor that power the memory card
2helpful
2answers
Help me fix a Parsing error in file C:\program files\HP\ Digital Imaging\bin\hp\qsclo\1033.xml.
In the following location there is a file called hpqscloc.dll. Right click the file and choose Properties.
Go to Version tab. What is the version of your dll? Mine is 120.0.26.58
Try double clicking the 1033.xml. Is there any error message when you do so?
1helpful
When I try to open the HP Solution Center I get the error message: Parsing error in file c:\Program Files\HP\Digital Imaging\bin\hpqsdoc\1033.xml
This message is because Microsoft XML services are having a problem.Here is what you could do to fix.
Step 1: Uninstall All-in-One software
Step 2: Restart the computer
Step 3: Install the Windows installer 3.0
http://www.microsoft.com/downloads/details.aspx?FamilyID=3144b72b-b4f2-46da-b4b6-c5d7485f2b42&displa...
Step 4: Download and install MSXML
Step 5: Reinstall All-in-One software
Hope this helps
System error 4-00
your problem is displaing 4-00 error code but it is not clear code befor 4-00 any alphabatic latter is displaing so, please tell full error code
like H-4-00
if H-4-00 code then go to dignostic code and press 14 and then press start button then wait it will rest your error code
it will restart it self after 1 second
now can strart your work machine is working ok,
My lg is displaing 0e can you tell me what this means.
Drain error, are you using h e soap? is there a kinked drain hose? That code will diplay after trying to drain for 10 minutes
Just cleaned the insides and now the machine wont displa anything on screen
Make sure memory is in properly and lcd cable is plugged properly.
Code u0doo
Anything that starts with a U usually means a computer communication problem.Does this displaed intermittently random or continously?
Displa colour missing
replace the lcd on the phone to correct this problem
Top ASUS Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
Paul Bade
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
