Yamaha keyboards can be prone to sticking keys due to the rear part of the key cracking around the return spring - if this is the case the only solution is replacing the affected key modules. However this problem generally only occurs with long term use by very physical players.
Otherwise the problem may be caused by a build up of dust / fluff between adjacent keys - try raking out the spaces with a thin piece of fairly rigid plastic (maybe a credit card might work?)
Testimonial: "thanks, i believe you know your pianos. [email protected]"
