Master
- Posted on Feb 25, 2011
Re: My Whirlpool Imperial Series washing machine will not...
- Check the voltage going to the drain pump, and replace the drain pump if it is found to be bad.
- If you are getting no voltage to the drain pump, your control board or drain pump wiring may have been damaged.
- If the machine fills up with water, but doesn't drain, this is usually fixed by replacing the drain pump, un-kinking and clearing out the drain hose, or cleaning the drain pump and hoses out.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
