What you need is an exchange or repair of your ZSUS board:
http://www.coppelltvrepair.com/p/485/lg-42pc3d-zsus-exchange-service-for-dark-grainy-screen-problem
SOURCE: Part # for a Y Sustain Board Cable Ribbon
why are you replacing it? what went wrong? mine just stopped lst nite and jsut ties to turn on. email [email protected]
SOURCE: Conwa 42" PDP Plasma TV with Orion PCBs
I have one and have been told the main board is not working.
Cant get parts. Do you want to sell your main board.
SOURCE: No picture, audio OK, HP PL4260N, outside HP's repair for common Problem
Yes you have to replace the Y scan board... the bad part is that this is a common problem with the HPL4260 model TVs and HP knows it. However they will refuse to fix this issue if your TV does not fall with in their serial range of those they claim have faulty parts. I called HP, and the hardware Tech admitted that HP used some cheap sub standard parts in ALL of the models shipped HPL4260... not just the ones in the serial range they (HP) claim... this was yesterday (03 December 2008). However since HP no longer even carries the parts you have to buy them yourself... you can find the parts here: http://www.ued.net/website/index.html
you will need to buy: TNPA3243AB-PA and TNPA3242-PA the Upper and Lower data output scan boards.... aka Y scan... that is according the the HP Tech I spoke to...
SOURCE: 42PC3D 42 in. Plasma Television: SCREEN ON 42 IN. PLASMA LG PICTURE LOOK DARK YOU C...
how dar is the picture ?
i can help you if you have more details
SOURCE: Ihave a LG 42 in plasma 42PC3D; there is areal
it is going to be a failure of the Z sustain board if you can see dark video. you can either replace the Z sustain board or the IPM that is bad on the Z sustain. the board is about $175.00 or so part number is 6871QZH034 I THINK.
Testimonial: "Thank you very much for your assisitance and knowledgeable staff.FIX-YA, You are clearly the best in Tech ????????'s. Sk8-B."
