You will need the service tech sheet...it should be located in the control panel.
On your display do you have any error codes displayed?
How are the temperatures in the freezer and refrigerator sections?
Here is the link to your control panel parts drawing. It will help you take it apart and check the power.Click on the link http://www.searspartsdirect.com/partsdirect/part-model/Maytag-Parts/Refrigerator-Parts/Model-MFD2561HEB/3048/0161000/M0704044/00007?blt=06&prst=&shdMod=
Here is the link for your wiring schematic.
Click on the link http://www.searspartsdirect.com/partsdirect/partsdirect/showSubComp.pd?imageUrl=http%3a%2f%2fc.searspartsdirect.com%2flis_png%2fPLDM%2fM0704044-00018.png
If you have never used a volt meter or have not repaired or checked incoming power or experience with electronics I suggest you call for service.
If you have a volt meter and you have power to the refrigerator check the incoming power to the control panel.
Post answers and results of power check please.
Keith
Seems everthing is good but the touch pad....
Touchpad must be bad,,,,,you can take it out and look it over....maybe see some black mark or melted on it,but usually you will not see any witness marks on them,much like if your keyboard goes bad.
I would suggest if ordering a new one order from here Repairclinic.com
Here is the part number Y67005640
Repairclinic Item # 1246625
They have a one year warranty even on electrical parts. NO questions asked. Even if you decide to get a new refrigerator in the following year,simply send it back.
Keith
again....I cant stress it enough...ensure power from control to touch pad
my touchpad power is on. The fridge temp is at 38, the freezer is at 0. the door alarm LED is green. However, the touch keys themselves are not responsive, and I can't adjust the temperature.
Is your solution still valid?
did you get my reply? the power is on, fridge temp is at 38, freezer at 0, door alarm LED is green, but the touch buttons themselves are not responsive
Thanks! this seems the right solution.
