3 month old lg lcd/ledtv 42 le5500. While trying to read from hdmi set turned off. Now the power indicator only works. No sound and picture. Power indicators blinks on remote signal
Many LG LCD television owners report having a problem with their televisions where the screen powers on, but then lasts only a few seconds or a few minutes before powering itself off again. The problem usually occurs with brand new televisions, and in this case is inside the television itself. If your television is powering off unexpectedly, contact LG so it can be serviced.
I have been having the same problem with my LG. people say there are bad capacitors on the power supply board. I don't have the know how to replace them and don't have the money to pay. I can get mine to work by blowing hot air with a hair dryer into the back of my tv through the vents over the board. Heat it up for a couple minutes and turn it off and then back on and the picture comes back. I just never turn the set off now.
If you are using a powerstrip may not be supplying enough power to run the LG HDTV and your HD receiver. If you are using a powerstrip make sure the receiver is plugged directly into the wall. Otherwise this may be a grounding issue please reply if this doesn't work and we can look into some other possibilities. Daniel Busa DISH Network Customer Service
I have had the same problem off and on with my 47LG70 for months. When the "popping" noise happens, the blue light in the corner stays on, so I know the tv is still on (sometimes I still have sound, sometimes I don't). Sometimes the screen goes black, but other times it is blue. If I turn the tv off then on again, it might stay on for seconds, minutes or hours. It's been very frustrating.
This seemed to happen right after I got my new Comcast box, which came with an HDMI 1.3 cable. I read somewhere online that this tv might not be compatible with that cable, so I unplugged it and am using component cables again. I just did this today, so I don't know if it will work, but so far the tv has been on for 30 minutes with no problems.
I'm pretty ignorant about HDMI compared to component cables. I imagine I will not get as good a picture with the component cables, but I am willing to sacrifice quality if I can just get the darn thing to work. Mine is also only 18 months old.
Hope this helps. If it doesn't, maybe someone else out there can help us both.
This is probably bad capacitors on the power supply board. My LG 42LB1DR has a known problem with this and I replaced the four bac capacitors myself and saved 5-6 hundered dollars that I was also told that it would cost to fix. I fixed for under 10 dollars and about 20 minutes. LG knows about it but they dont really want to admit it. My TV was only 26 months old when this happened. The four capacitors are made by Samxon and are 2200uf @ 10v. They are junk so even if you have the entire board replaced for say $200 its just going to happen again. They need to be replaced with a different brand.
