1994 Ford Econoline Logo
Posted on Feb 25, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Wiring diagram for rear door lock/handle - 1994 Ford Econoline
Anonymous
Level 2:
New Friend:
  • Expert 60 Answers
  • Posted on Feb 25, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
60
Questions
0
Helped
18694
Points
197
With or without memory locks can email you a diagram ,e mail me @ [email protected] give me year and engine size and is it a e150,e250 ext.
5 Related Answers
jaysonemanme
Jason Phillips
  • 500 Answers
  • Posted on May 29, 2009
SOURCE: Need detailed diagram of 1998 latch mechanism to remove connections from it
there is no diagram... the latch is also a non-servicable latch, so if your problems in the latch- it needs a latch. i would look more closely at the outside door handle itself as i have seen a few of them break on the E series vans.you may be able to get detailed instructions thru autozone.com or @ autozone. hope this helps and good luck
Anonymous
  • Posted on Feb 09, 2009
SOURCE: Rear Passanger door lock won't open
Perhaps you need to check whether or not the child safety lock is ON/OFF...it can be changed with your key. Check in the manual to make sure where this can be done...
Anonymous
  • Posted on Apr 27, 2009
SOURCE: Exterior rear door handle on Honda Accord 2001
To Remove Door Panel on 2001 Honda Accord:
A: To remove the plastic piece with the door lock button and door handle connected to it:
1- Remove the screw in the middle located behind a plastic cover button
2- Push (slide) the whole assembly Forward (toward front of car)
Besides the screw, it is held in place by 3 hooks on the backside that hook into holes in the metal door frame
3- Now unhook handle from small metal bar going through door by pushing (toward door) plastic clip (blue?) off of the bar, then the bar will come out of the clip hole, thus releasing the handle.
4- Depress little grey button /bar (purple painted on it)on elec. connector to seperate connector, thus releasing door lock switch
Now the whole assembly (metal handle, door lock switch, and plastic piece) will come off door panel
B: The door is held on by 2-screws, 7-plastic snaps/plugs, and 1-plastic plug.
The screws are located: bottom of hand hold and the other behind the handle, both covered by little covers that have to be pryed off to access the screws.(hint: the screw with the built in spacer goes behind the handle when you are trying to reinstall)
The 7-plastic snaps: 3 across bottom and 2 on each side. Not visible, they are mounted to the inside of the panel.
The 1-plastic plug is visible at the upper front of the panel and is the same color as the surrounding trim
C: Take off the big plastic triangle piece above the door panel and behind the mirror. Pull/pry off. It has 2 snaps holding it on. one near bottom and one near the front.
D: Light lens prys off from bottom. Unscrew (1/4 turn) the light assembly with bulb still intact from backside of panel
E: Remove the Hand-Hold/window switch assembly:
Randy Fitz
  • 112 Answers
  • Posted on Jul 07, 2009
SOURCE: electrical wiring diagram for door lock
Try "clearing the cache" by removing the negative battery cable for a few minutes. Before doing so, be sure you know how to reset the clock and radio codes & presets.
Anonymous
  • Posted on Jan 31, 2010
SOURCE: volkswagon Golf Mk4 rear door handle locked!
how to take a mrk for golf door handle off on the frount door in driver side ?
2004 Hyundai Santa Fe rear driver side door the outside door handle never worked you can only open it from the inside. accidentally flipped on the child safety lock now I can't open the door at all
It is fairly clear the door handle has detached from the wire that releases the latch. As you cnnot open from the interior handle currently you can only detach the door card and reatach the wire to the door handle. You might have to remove the seat adjacent to the door. I think it is probably a weekend job if you intend doing it yourself. There is no other way it could be done without inflicting damage I think. Essential for safety if you are carrying children/pets in the rear
Good Luck
1helpful
How do you remove the door handle from the subaru forester
For Doors not getting open with remote or key problem, there are help links provided below. Click the link below to go through its procedure and troubleshoot the problem: ----
Drivers side front door will not open from inside or outside?
http://technoanswers.blogspot.com/2012/01/ford-f-350-crew-cab-drivers-side-front.html
Car door will not close?
http://howtobyme.blogspot.com/2011/11/car-door-will-not-close.html
All power door locks not working?
http://howtobyme.blogspot.com/2011/11/all-power-door-locks-not-working-on_14.html
Repairing car Door lock Actuator?
http://howtobyme.blogspot.com/2011/11/repairing-car-door-lock-actuator.html
How to Access car door panel?
http://howtobyme.blogspot.com/2011/11/how-to-access-car-door-panel.html
Vehicle door panel components?
http://howtobyme.blogspot.com/2011/11/vehicle-door-panel-components.html
Truck Door will not close?
http://schematicsdiagram.blogspot.com/2011/12/ford-truck-door-will-not-close.html
Where is Cars Door control Module located?
http://schematicsdiagram.blogspot.com/2011/12/where-is-cars-door-control-module.html
Power door locks not working?
http://schematicsdiagram.blogspot.com/2011/12/power-door-locks-not-working.html
Door ajar light stays on?
http://technoanswers.blogspot.com/2012/01/door-ajar-light-stays-on.html
Door locks not working?
http://technoanswers.blogspot.com/2012/01/door-locks-not-working-on-ford-explorer.html
Front Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/front-door-dis-assembly-diagram-for.html
Rear Door dis-assembly diagram?
http://repairhelpcenter.blogspot.in/2012/02/rear-door-dis-assembly-diagram-for.html
How to test Power door locks?
http://repairhelpcenter.blogspot.in/2012/02/how-to-test-power-door-locks.html
Doors will not open with Remote?
http://schematicsdiagram.blogspot.in/2012/02/lexus-doors-will-not-open-with-remote.html
How to replace Door Hatch ?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-hatch-on-acura-integra.html
How to remove Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-remove-doors-on-acura-integra.html
How to Replace Doors?
http://repairhelpcenter.blogspot.com/2011/11/how-to-replace-doors-on-audi-a4-and-vw.html
Remote will not unlock Rear door?
http://schematicsdiagram.blogspot.com/2011/12/remote-will-not-unlock-rear-door-on-gmc.html
Door locks or windows not working on car?
http://schematicsdiagram.blogspot.com/2011/07/door-locks-or-windows-not-working-on.html
Central locking not working?
http://schematicsdiagram.blogspot.in/2012/03/this-is-how-system-operates.html
This will help.
Thanks.
Door will not open with handle or interior handle. The door lock unlocks and locks with the auto door lock
This will help.
Thanks.
4helpful
The left rear door window fell off the track. How do I remove the door panel to access it.
This is the complete procedure you stop when you see the problem.
1. REMOVE REAR DOOR INSIDE HANDLE BEZEL
(a) Remove the screw.
(b) Using a screwdriver with its tip taped, disengage the 2 claws A.
(c) Pull out the the rear door inside handle bezel in the direction indicated by the arrow, disengage the claw B, and remove the rear door inside handle bezel.
2. REMOVE DOOR PULL HANDLE
(a) Using a screwdriver wrapped with the protective tape, disengage the 2 clips and remove the door pull handle.
3. REMOVE REAR DOOR TRIM BOARD SUB-ASSEMBLY
(b) Disengage the 7 clips.
(c) Disconnect the connector and pull up on the rear door trim board sub-assembly to remove it.
4. REMOVE REAR DOOR INSIDE HANDLE SUB-ASSEMBLY
(a) Remove the bolt.
(b) Disengage the 2 claws and separate the rear door inside handle sub-assembly.
(c) Disconnect the 2 cables and remove the rear door inside handle sub-assembly.
5. REMOVE REAR SPEAKER
6. REMOVE REAR DOOR SERVICE HOLE COVER
(a) Disconnect each connector and remove the rear door service hole cover.
HINT:
Remove the remaining tape on the door side.
7. REMOVE REAR DOOR GLASS RUN
(a) Connect the window regulator switch assembly.
(b) Fully lower the door glass.
(c) Remove the rear door glass run.
8. REMOVE REAR DOOR WINDOW DIVISION BAR SUB-ASSEMBLY
(a) Remove the 2 bolts, the screw and rear door window division bar sub-assembly.
9. REMOVE REAR DOOR QUARTER WINDOW GLASS
(a) Pull out the direction indicated by the arrow, remove the rear door quarter window glass and rear door quarter window weatherstrip as a unit.
10. REMOVE REAR DOOR QUARTER WINDOW WEATHERSTRIP
11. REMOVE REAR DOOR GLASS SUB-ASSEMBLY
(a) Remove the rear door glass sub-assembly as shown in the illustration.
(b) Disconnect the window regulator switch assembly.
12. REMOVE REAR DOOR WINDOW REGULATOR SUB-ASSEMBLY
(a) Disconnect the connector.
(b) Loosen the temporary bolt.
NOTICE:
If the temporary bolt is removed, the rear door window regulator may fall and become deformed.
(c) Remove the 3 bolts and the rear door window regulator sub-assembly and the power window regulator motor assembly rear as a unit.
(d) Remove the temporary bolt from the regulator.
13. REMOVE POWER WINDOW REGULATOR MOTOR ASSEMBLY REAR
(a) Using a "torx" driver (T25), remove the 3 screws and power window regulator motor assembly rear.
14. REMOVE REAR DOOR LOCK ASSEMBLY
(b) Remove the bolt.
(c) Using a "torx" socket wrench (T30), remove the 3 screws.
(d) Slide the rear door lock assembly downward, pull out the link from the outside handle frame, and remove the rear door lock assembly and cables as a unit.
(e) Remove the door wire harness packing.
(a) Using a "torx" socket wrench (T30), loosen the screw.
(b) Disengage the 2 claws and remove the rear door outside handle cover.
(a) Disengage the 2 claws and remove the rear door outside handle pad rear.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/flavio_517b938f50183b92
Thank you for your response , been going crazy here...got panel off enough to put hand in but don't know where to pull to unlock door.
Jaguar 2000-06 - Locks & Lock Systems
Power Door Locks - Removal & Installation
Door Lock Switch
Door Lock Diagnosis & Testing
  1. Visually inspect the following:
    Misaligned door(s), hood or luggage compartment lid Door latches Actuating rod Exterior door handle Interior door handle Door lock cylinder Cable Luggage compartment lid exterior release switch Fuse(s) Wiring harness Electrical connector Door lock actuator Remote transmitter batteries Vehicle battery Remote transmitter Door lock switch Front electronic module
  2. If an obvious cause for an observed or reported concern is found, correct the cause (if possible) before proceeding to the next step.
Door Lock Motor
Coupe And Convertible
  1. Turn ignition key to position II.
  2. Motor door glass to fully raised position.
  3. Turn ignition key to position O.
  4. Disconnect the negative battery cable.
  5. Remove door casing for access.
  6. Remove door water shedder.
  7. Position PVC secondary water shedder for access.
  8. Slacken and remove the door glass rear runner lower securing screws.
  9. Reposition door glass rear runner. Mark the position of the glass rear runner upper securing screw.
  10. Slacken and remove the upper securing screw and move the runner away from the glass.
  11. Disconnect door handle and lock barrel (driver door only) operating rods from latch links.
  12. Slacken and remove the three latch assembly securing screws and position latch for access.
  13. Remove latch motor harness multiplug from mounting bracket and disconnect multiplug.
  14. Release operating cable from door handle. Move inner door handle to the locked position. Remove operating cable outer abutment from support bracket. Disconnect cable inner from door inner handle.
  15. Remove lock motor assembly from door.
  16. To install, reverse removal procedure.
    Fig. Removing door lock actuator
Sedan
  1. Remove the door window glass
  2. Detach the interior door handle.
  3. Detach the actuator remote cable from the interior door handle.
  4. Remove the interior door handle.
  5. Detach the door window glass run.
  6. Remove the exterior door handle retaining screws.
  7. Remove the front door actuator retaining screws.
  8. Reposition the front door actuator and exterior handle.
  9. Remove the front door actuator and exterior handle.
  10. Disconnect the front door actuator remote cable.
  11. Detach the door lock cylinder connecting rod (1).
  12. Detach the exterior door handle connecting rod (2).
  13. Remove the front door actuator (3).
  14. To install, reverse removal procedure.
    Fig. Removing door lock motor-Sedan
Hope this helps.
2answers
The sliding door on the passenger side is stuck closed and will not unlock either manually or electonically. I have the panel off and the black plastic pulled down, but am unable to get the electical...
good day, well sir your so close from opening the doors. if you find the metal wiring that connects to the door lock then you have to force it a little to let loose. Its gonna be a little tight coz the electronic lock is still connected. if its too tight try removing the steel wires from the power lock connection then try letting the steel wires again. hope this helps and have a nice day.
5helpful
4answers
97 Passat left front door won't open from outside - will open from inside if lock knob is pulled forcefully. I have new outside handle (not yet installed). All locks open properly with key. I have sought...
Hi.
Heat will not help and can damage the door lock mechanism further.
You can try lubing the door lock, but I do not thing it will help. I think there may be something wrong with the mechanism, or you will get the same problem from outside and inside.
If the door is opening from the inside , then the door lock mechanism My still be working. On VW the outer handle is connected to the lock by a steel wire, or by a metal shaft.
To access the door lock you need to remove the internal door panel. The door panel is held by hidden screws located on handles and by a set of clips located behind the panel near to the panel border.
I have service manual for several VW models, I will see if I can find the manual for 1995-1997 Passat and I will eventually send the diagrams to undo the door and access the lock.
3answers
Rear door stuck on 1997 Pathfinder...Have
go inside, lift on handle, then beat the **** out of the door pounding it like your trapped in it trying to get out. latch mechanism is probably corroded and froze shut. once open, spray with wd40 and work the lever a lot. then get door panel off to see if handle is broken inside
2helpful
1helpful
Drivers side widow will not go down more than 2 inches
A) Remove the screws in the following locations:
  1. Door handle
  2. door grip
  3. Middle of panel, 3/4 down the panel from the top
B) Removal of door Handle
  1. Use caution
  2. Slide the door handle in the direction of the motor
  3. The door handle is now freed from the door
C) Partial removal of door panel
  1. Insert a dull instrument into the port that is located on the panel roughly half way down the panel and the side the furthest from engine.
  2. Carefully pry the panel loose.
  3. With your hands, remove the panel by its contour. There are roughly 10 or so plastic plug
D) Tricky Part; Removal of door Handle
  1. Free the door handle from the panel, by carefully pushing it through the panel on an angle...
  2. You can now push the panel up beyond the door lock button.... then...
  3. The wiring haness is now exposed.
E) Wiring Harness
  1. You now un plug the wiring harness from:
  • Door handle
  • Lower courteosy light
  • Electric window controls (three wires)
F) Final steps
  • Lift the panel up and over the door lock button.
Now to your window problem.
When I examined the problem that I had with my Odyssey, I found the following:
  1. Two bolts were missing;
  2. The other tow bolts were lossed;
  3. The motor had shifted positions.
Top Ford Experts
ZJ Limited
ZJ Limited
Ronny Bennett Sr.
Ronny Bennett Sr.
Thomas Perkins
Thomas Perkins
Are you a Ford Expert? Answer questions, earn points and help others
