try the following sites
www.eserviceinfo.com/equipment_type/model###
www.freeproductmanual.com/manufactures_name/model### www.info.com/manuals
www.s-manuals.com/manufactures_name/model###
at the browser type the following information
sunbeam disassemble procedures for make/model ###
if the motor isnt making a noise then it could be the brushes in the motor that are worn.. or it could be the fuze in the plug have you tried a new one in there
I would propose to solution to your problem,
one. Try getting some clear contact and cutting a a square or circle a little more than the size of the dial. Removed the dial if possible and later clear contact over the surface.
Two. Get some clear nail polish and cover the markings on the dial with thin coat.
Warning warning warning!!! (Test the nail polish on a surface that is not exposed, for example underneath) to make sure that the nail polish does not react with the surface of the mixer.
Regards
Trevor
Hi MITCH, Happy New Year!Somebody at Sunbeam must have been asleep when the mixer passed by on the production line...duh?I hate when that happens.The good news is that you can download a PDF Users Manual from the Sunbeam website. Just click on this link Heritage Series 2353 Mixmaster and look for your M-I-L’s model to about ½-way down the page.Open the file and save it to your PC. I’m not very keen with the way Sunbeam lays out their User’s Manuals. You’ll need to do some editing and repaginating to get it into a format that your M-I-L- can use, but at least you’ll have it.You can send it to her electronically or print just the English pages and mail; your choice. Good Luck.I hope this helps. Howard, Burke, VA If this solution has been helpful, please rate it, thanks! - hslincoln
The speed control on the back is simply a variable resistance potentiometer, the same thing that controls the volume on older amplifiers. The output current to the motor is supplied by the printed circuit board in the bottom of the unit. This allows gradual increases in speed to avoid over-torquing the motor on speedup. Even the poshy-posh-posh mixers do this.
At least it still works. The most common problem is the cheap plastic drive gears that strip out with a mild cookie dough, this jams the beaters together and requires burial-at-dumpster.
http://www.repairclinic.comThis is a helpful website with an 800 number and they are good about helping with the fix. You probably have to replace worn gears and or bearings.
