SOURCE: I have a MAYTAG legacy
hello bz... there can be no hot water wash or hot cycle without hooking up a hot water supply line. Also, you must plug that hot water inlet, the correct plug is available at most hardware stores. Finally, yes it is normal for the machine to stop before draining, as the transmission shifts. If the machine is very noisy, that is not normal. To reduce that noise you could put the machine on a piece of thick carpet to deaden the noise a bit. Joe
Thanks for choosing Fixya!
Testimonial: "Thanks Joe "
