Question about Sony BDP-S360 DVD Player
My player is very selective about which DVD's it will play? I recently was given a DVD with movies burnt from a computor but it will NOT play?? It has been suggested that I try to make my player "multi-regional" but cant find out how?
  • topcattours Feb 26, 2011
    To walesarumi
    My dvd player is only 2 months old. It is not the laser that seems to be the problem, it appears to be the "region" thing.
    I have tried to find out how to "multi-regional" my player but with no success?
    Help!!!
    Otherwise my option seems to buy a cheaper dvd that will play anything.
    Ta
  • Sony Master
  • 6,993 Answers
how long have you been using this player? I suspect the laser (lens) of the player. I think the laser (lens) is weak that's why it cannot read data/files on DVD discs.
To confirm if actually its a laser problem, insert an Audio CD into the player and see if will play. If it plays, then obviously, your laser (lens) is weak. But if it doesn't play Audio CD, then it might still be the laser (lens) or a mechanism problem.
Get a lens cleaner, use it to clean the lens. If that doesn't solve the problem, get a screw driver, open the player's cover so that you can gain access to the lens, use a cotton board to clean the surface of the lens. This should clean dust or dirt that might be on the lens.
If non of the above solves the problem, then know that you need to replace the laser to a brand new one.
To replace the lens, remove the bad laser, use it as a sample to get exactly the same type and do the replacement. Note that replacing a laser (lens) needs a professional touch, so if you cannot replace the laser, get it to a repairman to fix it for you.
Once this us done, your player will play all DVD discs again.
Good luck and take care.
Posted on Feb 26, 2011
6ya staff
SOURCE:
Toshiba SD2010 DVD player
It can't read the files on the USB, wrong format.
Jul 14, 2017 | Televison & Video
Plays disc up to point where the movie should start and just keep restarting over and over?
I had a similar issue a while back. It didn't do it every time, just on one DVD.
When given the choice, go to "scene selection" instead of "play", and select scene 1. This bypasses the loop that the "play DVD" is on, and takes you straight to the movie.
Hope this helps!
--W/D--
Jan 30, 2011 | Samsung BD-P1500 Blu-Ray Player
Movies will not play on my player
If the cd´s play and the dvd´s don´t the only thing are the motor disc spindle looses velocity and can´t read the dvd
Sep 10, 2010 | KLH KD1220 DVD Player
Wont lode movies
Please check weather the DVD which your inserted i supported by the player.?
If someother movies plays then the problem is with the DVD which your inserted.The DVD might have not burnt in correct formatt.
Thanx
Jul 23, 2010 | Durabrand PDV-705 Portable DVD Player
I have a sanyo 3 disc dvd changer. says no play
first of all you need to check your manuel for dvd's that can be played as in burnt. as of right no cd/dvd changers can play dvd that are burnt. cd's can be played if it states on player. only normal cd's and dvd's can be played. also check your disc for marks on them like fingerprints etc. if you want invest in a great player like sony, pioneer, i have no problem with these players.
Jul 26, 2009 | Electronics - Others
Video freezes playing burnt dvd from computer on a dvd player
dvd players are finiky things they do not like burnt dvd's at all and some will just lock up computers on the other hand can handel those because burnt dvd's are in a coding format that computers can read much easier than a dvd player your best bet is to just buy the dvd non burned and see if that fixes it. good luck and If you ever need anymore help with electronics questions pleases dont hesitate to ask me at dragon_rage27@att.blackberry.net
thanks and good luck
Jan 08, 2009 | Technical Hifi Televison & Video
Burning movie using memories on TV3
If you burnt a DVD + , try getting a DVD - and burn to that or vice versa. Some DVD players play both the DVD + and the DVD -. Other DVD players will only play one of the two types of discsl
I burn all mine to a DVD +.
Jul 23, 2008 | Nova Development Photo Explosion Deluxe...
PS2
What it is, is from it playing on any burnt movies so now it won't play factory burnt discs only home-made burnt discs, try the movie on a home-made burnt disc. If nothing you can get a DVD player for like 20 bucks at wal-mart.
Apr 04, 2008 | Sony PlayStation 2 (PS2) Console
Jvc dvd player
seems like you put an NTSC dvd movie in there and the machine is set to Pal or the other way around. you need to program your computer to multi region setting. check the website for the unlock region codes. good luck
Mar 16, 2008 | JVC XV-S302 DVD Player
Wont play some newer rented DVD movies
If it is a blue ray, you need a blue ray dvd player.
Aug 26, 2007 | Curtis CMD5000 DVD Player
Sony BDP-S360 DVD Player Logo
94 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
