I have a lincoln power arc 4000 it sat for several years in my shop i tried to use it, the motor runs but it has no power output on the generator side or the welder side. I let it run for about 10 minutes thinking it would maybe come back to life but no such luck. do you have any idea on what my problem is?
Re: I have a lincoln power arc 4000 it sat for several...
Not sure what the problem is but I have similar unit and the engine died. If you are interested in selling the unit/engine please email me at [email protected]. My mobile is 1-868-366-9505.
as with any gasoline engine, you need, fuel, spark & air, take a moment to follow the progression of each of them, you will figure it out: example, test your ignition switch, clean, new fuel, getting spark to the plug? do you have a fuel stop solenoid attached to the carburetor?
Check the voltage sent to the field when running. It will probably be around 12 volts. You can try connecting a lantern battery BRIEFLY to the field to re-magnetize the field. Try bothe polarites.
Some have had a bad rectifier and one had a bad transformer that generaates the low voltage from the generated output. He had a broken wire from the winding to the wire from the transformer. He was able to reconnect the failed solder joint.
