SOURCE: hdtv lcd 40 in. broken screen face
There is no glass or plastic screen infront of the LCD panel.
If the screen is damaged you will need to replaced the entire LCD panel.
SOURCE: CRACK LCD TV SCREEN
Here is how it works. The price of the part itself is $1.279.99. There is a $1,740.00 CORE charge as well. The total would be $3,019.99. Now, you will get the core charge back ($1,740.00) when you return the old LCD. However, if the LCD has a mounted board on it and IT IS CRACKED, then you will not be able to return the core. And you will not receive your core charge back.
Please see below for a link to the screen you would need.
Bravia KDL-46V3000 LCD Screen
SOURCE: i have a sony 40 inches bravia flat screen hd and
Could be the decoder:
1. unplug the TV ans wait a few mins.
2. If you have digital cable box or dish tuner reboot those as well (likely your issue)
What you have is artifacting what that means is tiling garbiling and freezing this happends when the data in the digital stream just stopped hence Frozen.
Try those things rule out your cable tv box first or your sat box, if this is OTA over the air your antenna.
1. Try DVD's if it happends during a DVD you do have a decoder issue if it does not you need to talk to your cable tv or sat operator.
So you got 3 possiabilites here 1. the worse Decoder, 2 cable company or satalite provider, 3 your antenna is in the wroung position.
I sure this will help.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Testimonial: "i just hope this works"
SOURCE: my sony lcd tv screen cracked. what do i do?
If the screen is broken (Cracked) even if is
only a small line or area the only solution is replace the screen but as long
as the screen is cracked the total cost of the repair will exceed as much as
twice the price of brand new TV (these is because when is cracked the screen
has no core value & you have to pay for the core also that’s is even more
expensive that the screen itself )for that reason is economically unrepairable.
You have a couple 3 choices.
1st try to get a used screen that work with your
particular model & serial #
2nd, sell the leftovers of your TV as one piece
so some tv shop may use it for parts but you get no really a big amount
probably form 1oo.00 bucks to 300.00.
the last part is just throw it away (but
remember that they are considered industrial waist or hazard material then you
better take it to a recycler company)
