Televison & Video Logo
Posted on Feb 26, 2011
My Sansui SY-21-Eye TV is not showing picture is not horizontal. It is tilted with a little black line on top. I mean the whole picture is little tilted with a black line on top and on bottom some part is missing. Can you tell me which is the internal control part which can be used to adjuest the picture. Thanks in advance Manoj Shekhawat
Anonymous
Level 1:
  • Contributor 1 Answer
  • Posted on Feb 24, 2012
Anonymous
Contributor
Level 1:
Answers
Questions
0
Helped
191
Points
0
I too had the same problem but i have solved it. When i was scrolling all the channels, a hidden menu appeared. In that hidden menu all the tv functions are present. By changing the values we can adjust the resolution.
2 Related Answers
Anonymous
  • Posted on Sep 12, 2011
SOURCE: is there a service code
sansui k2k 21 tv service code
Anonymous
  • Posted on Jul 08, 2011
SOURCE: sansui sy 20 eye tv-
Please give me sansui sy 20 eye service menu code...pls urgent
2answers
What is the service key in remote for sansui sy-21-eye model tv
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
NB: Please read and understand well, the instructions to enter the service mode, before you begin. Be very careful. Note how to "EXIT" the service mode; after entering and adjusting data. This is very important.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
1helpful
Hi.. Mine is a sansui tv and I bought it 3 years back. Now it is showing a horizontal line on the screen. Sound is fine but I can't see the picture, I just see one white horizontal line on tv...
The problem is vertical failure. Vertical output section to your TV ahs the fault. You ahve to check the vertcial output circuit for any component failure or loose solderings.
2helpful
Sansui sy 20 eye tv- when power on/off only red led works, green led not working
We have a 27" MTS Stereo color TV. There are white horizontal lines at the top of the screen. We do have a DVR with Direct TV. How do we fix?
U can't.Only horizontal lines on the top parts of the tv screen or the lower parts of the picture screen.Or very light horizontal lines mix in with the tv screen pictures.The "CRT" the picture tube is slowly dying of old age.Quicker than they supose to.The late 90" these problems case show up alot more in standard tvs using CRT tube.Because the CRT and analog design about to be faze out of the market place.The glass molding and those radiation matrials,they used to make those "CRT" picture tube materials,not as good as before.
1helpful
Tv not showing picture but just horizontal line.
Failure of vertical output. Check vertical output components.
2answers
How to enter into Service Mode in Sansui Hard Rock 21 eye model
If you wish to get some details; visit the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
2answers
Horizontal White Line
Sounds like something is getting hot causing voltage loss or drive pulse loss to the vertical IC. Maybe you have a bad solder joint. Try tapping the circuit board around the vertical section. A capacitor could be heating and opening up. Stargazer Also you might try using circuit cooler spray and make the problem show up.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
