first check network type u make it automatic and if its shOw no signaL bar u check if ur sim registration is completely done BY providers. I hope it will work
Hope you need to refer to the nearest mobile service for FLASHING! So that you can load other themes later of your choice. The first thing is remove all the corrupted file(s) or the theme which made you upset..
If you forget the security code means get the master reset code for that one, master unlock code is a code that completely resets your phone, removing any security locks , get the code from this site www.unlock-free.com/nokia-master , it has the best services for the master reset code for your Nokia 5130 model mobile.....I hope that it may helpful to you....
Press *#7370# to do full reset.
If this doesnt work for you, then the handset needs to be flashed with new firmware.
You can try Nokia software updater (download it free from Nokia website)
Failing that, you will have to take it to repair shop to be flashed using a service box.
Good luck.
This problem has no specific solution, but the only and the final solution is "Flashing". For nokia, Ufs and Jaf boxes are the best flashing software. If these two can't flash your handsets, then there must be internal problem like cpu or power supply ic. If this is the case, repairing or getting repaired would be tough.
If all your 20 sets aren't working and displaying the same problem and asking for the same key, you better take another look at the flashing software. There must be error and something must be wrong with it. I wonder how 20 pcs got the same problem, you must look into the matter very carefully, otherwise, you'd damage more sets. You also need to replace your data cable for the particular model.
