Question about Zhone 1518-A1-NA Wireless Broadband Router - 54 Mbps 1 x ADSL Network WAN, 4 x 10/100Base-TX Network...
What is the ip address on the modem to check incoming connection speed?
    Sergeant:
    Champion:
  • 342 Answers
Usually it starts with 192.168.1.1
Posted on Feb 26, 2011
Testimonial: "Thank You."
    New Friend:
  • 162 Answers
Call your service provider for instructions
  • Keith Deininger
    Keith Deininger Feb 28, 2011
    If you would like to check your Internet connection speed there are 2 great sites that are used by most ISP installation techs.
    www.speedtest.net
    and
    www.pingtest.net
    This first one will validate how fast you are able to transmit packets from your computer to the testing server. Download speeds will always be higher than upload speed. This is normal as most of what we do is down streaming data from websites, email, etc.
    The second site will allow you to test the latency of packet transmission. What this means is it is measuring the "jitter" on the wire. You should pick a testing server that is closest to where you live. This goes for the speedtest site too. The site will know who your ISP provider is and will give you very accurate results. If the results are rated poorly, you might want to begin by replacing the coaxial cable (if it is a cable modem) from the wall jack to the modem. Retest the connection note any differences. You will also want to note what time of day you run the tests.
    Depending on where you live, either in a single family home, apartment, inner city or out in the burbs as each of these factors will affect your connection speeds and QoS (quality of service). for instance if you live in an apartment with everyone using the same ISP for cable TV, Internet and VoIP phone service, connection speeds will much slower due to everyone using the same data connection pipe.
    Try those things out and let me know what you find. If you still experience slow speeds, you should contact your ISP provider and have them dispatch a tech to test the lines from the pole where it comes into your home and into the network. I could be there is a problem with the line or tap coming in from the street level.
    As for the posting of the support site, I would stay away from them and deal with the professionals here.
    Thanks, Keith, MCSE, CISSP, CSSA
    New Friend:
What is user and password please help me
Posted on May 30, 2014
6ya staff
SOURCE:
Why will it not connect to the internets IP address?
If you reset the modem and ip address will not change and remains same hence it is static ip address.If you reset the modem and the ip address change ,it is dynamic ip address.
You can get the Ip address from your internet service provider.you can check the ip address using the site Ip-details.com .
Jan 25, 2013 | RCA DCW615R Wireless/Cable Modem
Problem with RV042 linksys router
Ah Wan 2 doesnt like to receive a DHCP address you will have to get static Ip addresses
Jul 11, 2009 | Linksys RV042 VPN Router
Why won't my satelite modem communicate with my ethernet connection in my systemax venture computer.
hi there,
have you check your network connection,try to go control panel, check if you a network connection,check the driver of your ethernet on device maneger,if no driver install your lan installer,if your network is working properly,on network connection left click
local area connection properties.click tcp/ip,click properties and
type on the box your ip address manually example 192.168.0.1 and click that no. on the box to get your subnet mask,then close all until you get ip address manually,checking ip address on your network check on status,if you got manual ip address,then back again to network connection this time obtain your ip address on tcp/ip properties click obtain an ip automatically from modem,
besure to connect your modem on lan port.regards
Jul 04, 2009 | Systemax Computers & Internet
Ip 3rd time is chainging.all time speed is going down
what ip are you referring to? most internet service providers provide dynamic ip addressing to their residential customers and dynamic ip addressing means that your ip address will be changed periodically. Static ip addresses (ip adoes not change) is usually provided for business consumers.
as for the speed, if you subscribe to 4Mbps speed package, what it actually means is that you willbe getting UP TO 4Mbps speed. that would explain why your speed goes down. you will not always have 4Mbps.
Apr 22, 2009 | Computers & Internet
Can;t use intent on mobile
Here is what you should do step by step:
I.Configure your Computer
1.Install Bluetooth Adapter
2. Bluetooth Configuration->Local Services-> Add Serial Services ->Bluetooth Serial Port->Properties
Check – Startup Automatically
Check – Secure Connection
COM Port: COMx( mine is COM6)
3.Control Panel -> Phone and Modem Options->Modems->Add-> Check Don’t detect my modem->Next->(Standard Modem Types)->Communication cable between two computers->Next-> on witch port do you want to install it ? -> Selected ports -> COMx ( in my case COM6)->Next->Finished
Now in phone and modem options->Modems you should have : Communications cable between two computers : Attached to : COMx ( COM6 my case)
Select Communications cable between two computers -> Properties->Modem-> Maximum Port Speed : 115200 -> ok ->ok.
4.Control Panel ->Network Connections ->Create a new connection-> Next->Set up an advanced Connection-> Next-> Accept incoming connections->Next-> Check : Communications cable between two computers ->Next-> Check: Do not allow virtual private connections->next->next->select: Internet Protocol(TCP/IP)->Properties:
Network access : Check Allow callers to access my local area network
TCP/IP address assignment : Specify TCP/IP addresses:
To: 192.168.0.y (y=52 in my case)
->OK->Next->Finish
5.Network Connections
Bluetooth Network -> Enable
Internet Connection ( your internet connection ) -> properties->Advanced->Check:Allow other network users to connect trought this computer’s Internet Connection->OK
If all goes well : Bluetooth Network-> Properties-> Internet Protocol ( TCP/IP)->Properties Should have the following setting:
Checked Use the followind IP address:
IP address: 192.168.0.1
Subnet mask: 255.255.255.0
->OK.
6.Start->Control Panel->Administrative Tools->Services->Routing and remote access->Properties->General: Startup type : Automatic - this service MUST be started
**7.Install AnalogX Proxy http://www.analogx.com:80/files/proxyi.exe (for the latest version)
Proxy->Configure-> Proxy Binding: 192.168.0.x ( for me x=50 )->ok.
! If you use a proxy, remember to start it .
II. Configure Phone:
1.Install GnuBox - http://gnubox.dnsalias.org/gnubox/ ( for the latest version)
2.Configure Access point
Tool->Settings->Connection->Accces Points-> New Access point->Use Default Settings
Connection name: Bt
Data Bearer: Packet data
Access point name : Bt
User name: none
Promt Password: NO
Password: ****
Authentication: Secure
Homepage: none
Option->Advanced settings
Network Type: IPv4
Phone IP address: Automatic
Name Servers: Automatic
**Proxy serv. Address: 192.168.0.x ( for me x=50)
**Proxy port number: 6588
3.Configure all the applications from your phone witch require internet acces to use Bt Access Point
4.Configure GnuBox
Options->Install Set to GPRS
Options->Install Create Records
Options->Install->Copy settings from GPRS
Options->Install->set RAS login script
Exit GnuBox
Open Gnubox
Options->2box Bluetooth->Serial Port
Select – your computer
Do you want to require encryption? Yes
Options-> Install->change default AP
** Configure NetFront
Options->Settings->Connection
Enable Proxy : Yes
Proxy Host : 192.168.0.x ( in my case x=50)
Now you can browse the internet from your phone.
NOTE: First Configure the phone and your pc without the ** settings, and if you can’t browse the Internet form your phone then use the ** settings.
Hope this works fine.Thank you.
Nov 25, 2008 | Computers & Internet
Thomson router
dsl signal / light on modem ..ok
connection to computer ..ok
able to log-in to the internet service provider ..ok
check your IP address setting on the computer, must be set to automatically get IP address, same goes for the DNS setting.
Oct 04, 2008 | Computers & Internet
Dell latitude d800 laptop
The problem may be the modem has to assign an IP address to your laptop, what you may have to do is plug the laptop into the modem and see if the laptop recognizes the modem with no errors in device manager,
Next turn off the laptop and modem, reboot the laptop then modem for the modem to assign an IP address.
Mar 19, 2008 | Dell Latitude D800 Notebook
Emails
The default name server due to interaction with the router?s NAT firewall feature cannot resolve simple names such as ?mail?. There is a workaround for this: First, verify that the mail client is set up with simple server names. To view the server names entered into Outlook Express, click on "Tools", "Accounts". Highlight the mail account and click on "Properties". Click on the "Servers" tab. Under "Server Information", there are two fields called "Incoming mail" and "Outgoing mail". If these are simple names like "Mail" and not something like "pop.myisp.mail.com" then use this work around. Second, make sure that the TCP/IP settings are configured to obtain an IP address automatically. In Windows 2000 also make sure that the TCP/IP settings are also configured for Obtain DNS server address automatically. Replace the mail server names with the mail server IP addresses. There are a couple ways this information can be obtained. Contacting the ISP and asking is one possible way. The other way is to reconnect the original computer to the modem. Make sure the computer is restarted or that the IP configuration is released and renewed and that the computer has obtained an IP address from the ISP. Open a "COMMAND" window by typing "CMD" in the run dialog box located in the "Start" menu. At the command prompt, type "PING MAIL" where "mail" is the simple name of the incoming mail server. The ISP server will return an IP address for the mail server. Record this address. Do the same for the outgoing mail server (if different): type "PING MAIL" where "mail" is the simple name of the outgoing mail server. Open the mail client (Outlook Express, etc.). For Outlook Express, click on "Tools", "Accounts". Highlight the mail account and click on "Properties". Click on the "Servers" tab. Under "Server Information", there are two fields called "Incoming mail" and "Outgoing mail". Enter the incoming and outgoing mail server IP addresses into these fields. Click "Apply". Close the window and test the mail by sending an e-mail to the mailbox. (Send an E-mail to yourself. This will test the incoming and outgoing mail all at once)
Feb 16, 2006 | Belkin (F5D6230-3) Wireless Router
Cant get my emails?!!!
The default name server due to interaction with the NAT firewall feature of the router cannot resolve simple names such as ?mail?. There is a workaround for this: First, verify that the mail client is set up with simple server names. To view the server names entered into Outlook Express, click on "Tools", "Accounts". Highlight the mail account and click on "Properties". Click on the "Servers" tab. Under "Server Information", there are two fields called "Incoming mail" and "Outgoing mail". If these are simple names like "Mail" and not something like "pop.myisp.mail.com" then use this work around. Second, make sure that the TCP/IP settings are configured to obtain an IP address automatically. In Windows 2000 also make sure that the TCP/IP settings are also configured for Obtain DNS server address automatically. Replace the mail server names with the mail server IP addresses. There are a couple ways this information can be obtained. Contacting the ISP and asking is one possible way. The other way is to reconnect the original computer to the modem. Make sure the computer is restarted or that the IP configuration is released and renewed and that the computer has obtained an IP address from the ISP. Open a "COMMAND" window by typing "CMD" in the run dialog box located in the "Start" menu. At the command prompt, type "PING MAIL" where "mail" is the simple name of the incoming mail server. The ISP server will return an IP address for the mail server. Record this address. Do the same for the outgoing mail server (if different): type "PING MAIL" where "mail" is the simple name of the outgoing mail server. Open the mail client (Outlook Express, etc.). For Outlook Express, click on "Tools", "Accounts". Highlight the mail account and click on "Properties". Click on the "Servers" tab. Under "Server Information", there are two fields called "Incoming mail" and "Outgoing mail". Enter the incoming and outgoing mail server IP addresses into these fields. Click "Apply". Close the window and test the mail by sending an e-mail to the mailbox. (Send an E-mail to yourself. This will test the incoming and outgoing mail all at once)
Feb 16, 2006 | Belkin (F5D5230-4) Router
Zhone 1518-A1-NA Wireless Broadband Router - 54 Mbps 1 x ADSL Network WAN, 4 x 10/100Base-TX Network... Logo
498 people viewed this question
Top Zhone Computers & Internet Experts
Prashant M
Prashant M
Joe Goldman
Joe Goldman
Mike
Are you a Zhone Computer and Internet Expert? Answer questions, earn points and help others
