Question about Freezers
Frost buildup in frost free freezer
My friend's upright side-by-side fridge-freezer has a problem. It is making huge amounts of frost in the freezer, right around the place where ice is made, stored and dispensed. I don't know the make and model but not terribly old - around 10-12 years??? She says it'll even build up so big it prevents ice from going down the dispenser. She lives north of Houston and she says she thinks this is a "summertime problem." I thought it might be because of a worn seal on the door? How to test that?
Thanks,
NKSavage
  • alfonso2122 Dec 01, 2008
    I have a Whirpool refrigirator with a freezer model ET8WTEXMQ01, it is about 4 years old, and frost has been accumulating all over the freezer, I have cleaned it once, but the problem persists.. what should I do?
    Sergeant:
  • 152 Answers
There is a defroster built into the ice maker to melt the ice a little around the edges before dispensing on most ice makers it may need replacing.
Posted on Jul 28, 2008
6ya staff
SOURCE:
What number should i set the upright freezer control
Thank you for your inquiry, friend!
Normally it is recommended to set your Frigidaire upright freezer to zero degrees. It is your option to make it cooler if you choose too. I hope this information has been helpful. -Matt
Oct 15, 2014 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Why wont my freezer wont freeze everything else does
Try clearing all vents - inside (make sure vents not covered - in fridge and freezer) and outside (gently vacuum - the coil areas in the back and bottom of fridge)
Air needs to circulate in both parts (dependent on eachother)
Aug 29, 2014 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Upright freezer shuts off and leaks when there is any kind of ice buildup. has done this twice in 7 months. is this normal or is it on its way out?
I suggest checking the defrost circuit. Make sure the drain in the back of the freezer is clear first. Then check the defrost timer, switch, and heating element using a volt meter. You can download a schematic from the Sears/Kenmore website.
Jan 19, 2010 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Frost buildup in freezer
Remove the bottom panel from the front of the fridge. Look for a small motor with a screw slot in it. Turn the srewdriver slowly and only clockwise, until a click is heard. wait about 3-5 minutes and check if the walls of the freezer are getting warm. If they do all you need is a defrost timer. That's the thing you just activated, by the way. More often than not you can find them at the dump in the appliance pile, OR you may have just gotten it to work for another year. Keep a close eye. Dana
Aug 30, 2009 | Whirlpool 11.8 cu. ft. / 334 liter Upright...
My son got into my fridge lastnight-left open, now won't cool
evaporator coils is probably frosted from condinsation.shut door set at normal setting and give some time.
Jul 26, 2009 | Frigidaire Freezer Refrigeration White...
Top & middle shelves COVERED with frost/ice, not middle
That is normal. The refrigerant runs through those shelves. They are the evaporator side of the unit.That is where the freezing effect comes from.
Check door seals for leaking air.
Keep door openings to a minimum.
Get in there and get out.
Those things will help prolong frost/ice buildup.
Mar 12, 2009 | Whirlpool 16.7 cu. ft. / 473 liter Upright...
Freezer has frost in back- frig not coolling
You have a defrost parts issue.
Unplug the fridge. Remove the back freezer panel and check the defrost heater and defrost thermostat.
Without a model number I can not tell you where the defrost timer is.
Mar 04, 2009 | Kenmore Freezer 20.3 cu. ft. Frost Free...
Kenmore® (46-26072) Elite® 20.6-Cu. Ft. Frost-Free White Upright Freezer
Check these two things first.  1.  Is there a thick frost buildup on the back panel at the bottom half of the freezer?  2.  Do you hear the fan running inside the freezer?  Let me know what you find.
Oct 12, 2007 | Maytag Freezer MQU2057
Freezers Logo
368 people viewed this question
Top Freezers Experts
Dennis Boxerman
John Tripp
John Tripp
Marvin
Marvin
Are you a Freezer Expert? Answer questions, earn points and help others
