Apple iPad 64 GB 3G Tablet PC Logo
Posted on Feb 26, 2011
How do i reset the passcode - Apple iPad 64 GB 3G Tablet PC
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Feb 28, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2316
Points
If you forgot or lost your password for your iPad, you'll have to restore the iPad. Plug the iPad into your computer using the cable, and open iTunes. Click on your iPad in left pane and click the 'Summary' tab. Click 'Restore.' This will wipe all data from your iPad and effectively reset the device to factory settings, but it's the only way to reset the passcode.
Forgotten passcode how to reset my password on my kindle paperwhite
You may want to follow the instructions on the Amazon web site below:
https://www.amazon.com/gp/help/customer/display.html?nodeId=201176220
"If you can't remember the on-device passcode for your Kindle, you'll need to reset your device.
If you do not remember the passcode for your Kindle, you'll need to reset your device, which will remove all of your personal information, including your lock screen passcode and parental controls, Amazon account information, Wi-Fi settings, and downloaded content.
Any content you've purchased from Amazon is automatically saved to the Cloud and can be re-downloaded when you register your Kindle to your account again.
To reset your device:
  1. Tap the passcode field to bring up the onscreen keyboard.
  2. Type 111222777, and then tap OK.
To use your Kindle again, you'll need to connect to a wireless network and register your device."
Passcode is required to enable Touch ID on Ipad
This is plain and simple - you need the original passcode before you can add your fingerprint. If this was a used tablet - you can get the passcode from someone that has it - or you may be able to factory reset it using itunes and recovery mode.
Forgot passcode for your iPhone iPad or iPod touch or your device is...
If you need further help, reach me via phone at https://www.6ya.com/expert/michael_e7c2c48c6e65f808
Reset apple ipad passcode
There are different ways to reset Apple iPad passcode such as with iTunes. Follow below simple steps to reach the aim.
If Find My iPhone app is on, you can try the socond method: Reset iPhone password with iCloud Find My iPhone. The detailed steps are shown as below.
Step 1. Go to icloud.com and log in with your Apple ID and password on your computer.
Step 2. Click Find My iPhone. Then click All Devices at the top of your browser window.
Step 3. Select your iPhone from all the devices listed. Click Erase iPhone to erase your iPhone along with its passcode.
Step 4. Use the Setup Assistant on your device to restore the most recent backup of your device.
After the restoration process is finished, your passcode will be erased and all your data will be restored from your iCloud backup. You will now be able to access your iPhone without any passcode.
For more methods, check: How to Reset Password on iPhone
I need to reset my password for brighthouse tv on my ipad
As for resetting iPad password, an easy way is to utilize iTunes. Just refer to below guide.
If you have synced your iPhone with iTunes before you forget your iPhone password, you can reset your iPhone by using iTunes without losing data. Through iTunes, you can restore your iPhone from the last backup and remove the passcode from your locked iPhone while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPhone Passcode with Recovery Mode section below. The following steps will show you how to reset iPhone password with iTunes.
Step 1. Connect your iPhone to the computer with via a USB cable that your iPhone has trusted.
Step 2. Launch iTunes. If you've synced your iPhone with iTunes, then no "enter password" is required.
Step 3. iTunes will automatically sync your iPhone and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
Step 4. In the Summary window, you can see the option "Restore iPhone". Click it and follow prompts to choose the latest iTunes backup to restore your iPhone.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPhone without any passcode. And you can set your new password on iPhone.
How can i get passcode
Hi Donald. Do you forget the passcode?
If you have synced your iPad with iTunes before you forget your iPad password, you can reset your iPad by using iTunes without losing data. Through iTunes, you can restore your iPad from the last backup and remove the passcode from your locked iPad while retaining your data. If iTunes asks you to enter the passcode, try another computer. Otherwise, you have to follow the reset iPad Passcode with Recovery Mode section below. The following steps will show you how to reset iPad password with iTunes.
  1. Connect your iPad to the computer with via a USB cable that your iPad has trusted.
  2. Launch iTunes. If you've synced your iPad with iTunes, then no "enter password" is required.
  3. iTunes will automatically sync your iPad and create a backup file. If it doesn't, you should sync your iTunes and create a backup file manually by in the Summary window.
  4. In the Summary window, you can see the option "Restore iPad". Click it and follow prompts to choose the latest iTunes backup to restore your iPad.
After the restoration process is complete, your passcode will be erased and all your data will be restored from your backup. You will now be able to access your iPad without any passcode. And you can set your new password on iPad.
Set it up with thumb print when Iopened it up wont let me in without 6 digit passcode which I don't have
Well, when you first set up your IPad you had to create a passcode to get in. If you can remember what your passcode is click the link here and reset it. Forgot passcode for your iPhone iPad or iPod touch or your device is...
I forgot my password for my hisense smart tablet how do i reset it or open it again?
Have a hisense tablet and forgot the passcode how do I reset it I tried the reset button but it just turns it off want get past the passcode
Top Apple Tablets & eReaders Experts
nexrad_chris
NOEL
NOEL
John
John
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
