Reboot your computer as well as your scanner, also check your data cable if properly connected as well as the power cord of your scanner, else try to uninstall your printer/scanner and reinstall it again. Reboot again and try connecting again. Usually, it is not possible to use your scanner simultaneously while printing.
SOURCE: Can't install, fails every time.
had this same problem, go to Add and Remove Programs and uninstall "Bonjour" and then run the Kodak Setup and it will reinstall it.
SOURCE: My Kodak ESP5 won't scan...
Try to install the latest version of Printer software from www.kodak.com/go/downloads on your computer. then open the kodak home center software and click on scan pictures. Adjust the settings and you are ready to go. download the user manual from www.kodak.com/go/manuals. may be problem with scanner drivers. new software will fix up your issue. Enjoy.
SOURCE: purchased Kodak ESP 3250 yesterday. Not printing photographs.
Yes sounds to me like one of your ink cartridge is empty. Replace and try again.
Testimonial: "Hi - the printer was caput - had to be replaced. Thank you for help."
SOURCE: Kodak ESP5 AiO
Please clarify a few things for me so I can help you solve this issue.
Are you trying to scan from the printer to the computer? (pushing the scan command on the printers keypad to send the signal to the computer)
OR
Are you trying to scan from the computer to the printer? (Using the scan options in your software by choosing "start" and then "programs" and opening your printers software to choose the scan option)
If your scanning from printer to computer (using the printers scan option on the keypad) and your getting an error code, chances are the problem is you have not set up your defaults in the printers menu yet. To scan from printer to computer, the printer needs to know which program you want your document to scan to in your computer. If its a text document, some people choose "Microsoft Word" and the scan fuction sends your item to that program and opens it for viewing on your computer screen.
There are different programs to use for each type of fax that need to be set up in advance in your printer to be able to scan from printer to computer. Send pictures to a photo editing software and choose the size and resolution you want as "default". Do the same for setting up text documents before you try and use this feature to eliminate the error code.
To configure your options to scan from printer to pc, push the "menu" button on your printer and use the up and down arrows on the printers keypad to move through the choices. Find the command similar to "scan options" and follow the prompts to set the defaults on handling text documents and pictures and then save your choices by pushing the "ok" button on the printers keypad.
Try scanning again with your computer turned on and open to the desktop. Push the scan button on the printer and see if it sends the image or document to your computer screen. It should warm up, then scan and show a preview on your screen for you to accept or reject. If this does not happen, please asnwer my questions as listed above and clarify what you see so I can help solve this issue right now.
