Open the little door in the bottom left hand corner, unscrew the black cap and drain the water out.
If this doesn't fix the problem, you may need a new Drain pump. Unplug
the machine. Remove the filter recess by removing the one screw inside
and using a putty knife at the left and / or right edge and popping it
out. Pull the machine out about 18 inches and tip it back, resting it
against the wall. Remove two more screws behind where the recess was
holding the pump housing on. Reach under the machine and remove pump.
There is a tab to depress under the pump housing to release it from the
base. The pump motor is held onto the housing by three screws. Remove
them and inspect the impeller to see if it has come off the shaft. If
it has, pushing it back on will not solve the problem, as it will come
off again. Install new drain pump and reassemble.
I’m happy to help further over the phone at https://www.6ya.com/expert/jeremy_69f3cc28d95bf514
Check the end of your drain hose. I have to clean a mesh filter on the end of the hose that can sometimes cause draining problems. The drain filter / pump problems dont seem to exist with my machine so far, but the plugged drain hose does. I clean it out once a month. Hope it helps.
