Freezers Logo
Posted on Feb 27, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a Frigidaire A Rated Frost free fridge freezer Model FRC150FF 13 months old. I have noticed a build up of ice under the bottom drawer of the freezer compartment in the last few weeks. It is easy enough to remove but it is occurring more frequently now. Please can you help?
Anonymous
Level 3:
  • Master 1,531 Answers
  • Posted on Mar 03, 2011
Anonymous
Master
Level 3:
Answers
1531
Questions
0
Helped
406602
Points
4453
There is a chance that the drain hole in the back of the freezer is plugged or block and needs to be clean when the unit is defrosting the water is dripping in the cabinet instead of out the drain.
I have an old side by side we notice water on the floor every couple of days when we looked inside there is a ice build up and I guess when the fridge defrost ice bilds up and freezes and then water comes...
Hello, The drain behind the back panel in the freezer is frozen or blocked up. Remove the back panel remove as much ice as possible and pour boiling water in the bottom section under the evaporator. be careful not to touch the aluminum it will cut you or break. you will see the drain hole sometimes it takes a while to thaw all the ice. Hope this helps and please rate me Thank You.
5helpful
2answers
Icing up
I've just had a similar problem. I fixed it by removing the large panel on the back of the inside of the freezer. I found a large build up of ice at the bottom of the freezer which seems to have developed because the drain hole at the bottom of the freezer was blocked. I defrosted the ice, cleared the drain and now the freezer is working fine.
1helpful
Frigidaire upright--"Hi temp" warning light on door. Don't know why freezer temperatures are so high (into 30s), food is thawing. Electrical seems to be fine. Have not noticed problems with door. New...
2 months old should still be under warenty.
Check the freezer fan by opening the freezer door and pressing the door switch and listing for the freezer fan sound. If no sound then the fan motor could be bad.
Look at the back wall too see if you have frost build up. If you do then you have a defrost problem.
If thees are not your problem you could have a seal system problem. (( freon leak ))
1helpful
Side by Side Freezer ice build up and water in the
Either the drain hose is plugged up with ice and not dripping into evaporator tray, or the defrost unit needs to be replaced.
1helpful
Side by side fridge not cooling, not making ice
if it seems like the evaporator is getting cold then your sealed system should appear to be ok. you need the evap fan to transfer cold air into fresh food section. if not turning u need to replace fan motor. make sure your not getting to much frost build up on the evap.
FREEZER TOO WARM
Hi, Are you seeing ice or frost? Is frost building up on the freezer back wall? I can help you, just need to be clear.
Thanks
Vic
May 24, 2009 • Freezers
2helpful
2answers
Frosting & water dripping from freezer in Frost free freezer
Hi, You will find that your problem relates to the defrost heater in the freezer. You will need to take the drawers out and remove the back panel to access the evaporator. There is a foil heater that lays underneath the evaporator and it will need to be changed. Along with the klixon that controls it. This will ensure that both parts are good. Your problem will then be fixed no more water!
Good luck................
Dec 30, 2008 • Freezers
1helpful
Ice build-up
Defected DEFROST HEATER can cause frost build up on the panel at the back of the freezer,and freezer stop cooling and ice frozen on unit so air could not flow to refrigerator side.Water will coming out caused of unbalanced freezing,and causing the flooding of water in the floor. You must change this defroster heater assembly so it will works normal again..
Hope this may help;
Regards,
VOTIT
Puddle
all frost free freezers have to defrost the coils. there is a drain pan or cup in the bottom .. if it overflows or it can't drain out you will get puddles check the drain hose and drain cup or pan.. also check to see if you have ice inside the bottom of you freezer that would be a plugged or freezing drain hose..call for services if only 4 months old...
Top Frigidaire Freezers Experts
ZJ Limited
ZJ Limited
Are you a Frigidaire Freezer Expert? Answer questions, earn points and help others
