Question about Memorex MT2025D TV
Closed caption will not go off tried remote/manuel from tv/reset also did not work
  • 68 Answers
You must get into the menu and find close cap section.This will give you the option of enable or disable.
Posted on Feb 28, 2011
6ya staff
SOURCE:
How do I turn off the caption on this freakin Sharp Liq. Crystal T.V.? I lost the manuel! IT'S NOT A SANYO...IT'S A SHARP T.V. MODEL # LC40E77UM
hi,
For switching off the closed caption option do the following.
1. Press CC on the remote.
• This will present the Closed Caption information display.
2. Press CC while the Closed Caption information is
still on the screen.
• Press repeatedly until you select the desired closed
caption service as OFF.
ok
Feb 25, 2011 | Sanyo DS31520 31" TV
I need to set up cc however I dont know how and i dont have my manuel what do i do
Check the tv remote control look for the button said CC get it on to CC1,2,3 one of these numbers will show close captioning,if the the show have captioning.Or tries go into the menu goto Captioning or Text functions turn on 1,2,3 will get the captioning functioning.
Jul 16, 2010 | RCA TruFlat 27F520T 27" TV
I have a panasonic TV. direct tv remote for a . while programming the timer, somehow closed captioning got turned on & i after hours of trying to get it turned off, NO LUCK. it's driving me insane!!...
I could do better with a picture of the remote. Closed captioning is usually a multi-press button, that is each press takes you through each of the four types of closed captioning and then off.
You can enable closed captioning on a DVD Recorder, it looks like the TV, but its only on the picture from the DVD Recorder.
If you have a PVR, you could have closed captioning on on that device.
Try tuning off everything else to make sure it IS the TV.
Turn on the menu and find the closed captioning settings and set to OFF.
Press the close captioning button on the remote (If there is one) and press CC repeatedly until it says OFF.
Try and control close captioning, timer and menus with the ORIGINAL remote and not a programmable one.
Programmable remotes are not always completely compatible.
Mar 20, 2010 | RCA Universal Remote Control
How to turn off CC without original remote27ms4504
Noway to turn off captioning right away without the original remote.But U can unplug the tv for an hour,tv well reset itself back to original setting.The Captioning will shut off buy itself.Because captioning reqiure CC buttion on orignal remote and must manually turn on and off.
Feb 08, 2010 | Philips 27MS4504 TV
Closed caption / universal remote
Couple things to try:
On the remote - Press "Clear" button
May have to turn off CC in the TV menus. Try Menu on the remote and look for closed caption there.
If remote doesn't work, can try with buttons on TV itself to get into menu and turn it off.
Here's a link to the manual for that remote:
http://www.remotecentral.com/cgi-bin/files/rcfiles.cgi?area=other&db=devices&br=innovage&dv=universalremote&md=jumboremote&kw=&st=&ar=&dt=&so=&pg=1&file=others/innovage/jumbo-manual.zip
Mar 28, 2009 | One For All URC-4330 Remote Control
Can't Turn off Closed Captioning on Sanyo 36 in TV AVM-3658
Hi Hfrohman, This may sound crazy, but, press and hold the power button on the TV while unplugging it, continue to hold power button for 60 seconds or more. Release it and plug TV back in. Sometimes that will clear the settings.
I hope that works for you.
Jun 26, 2017 | Sanyo AVM-3658S 36" TV
Sharp Aquos LCD TV 52"
Does your cable company support CC?
Apr 08, 2008 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
No remote to turn off Closed Captioning
if your tv has a menu button on it enter and try ot turn it off via thr front control buttons
Apr 07, 2008 | Philips Magnavox Learning Universal Remote
Can't shut off closed caption
I have the JVC I Art 46" TV. The Close Caption was turn on accidentally by my grandson. After lots of searching for the original remote. I called JVC Customer Support. He told me to change the Close Caption settings to CC2 and T1. That fixed the CC without having the original remote.
Apr 10, 2007 | JVC AV-32F704 32" TV
Closed captioning
try uplugging the tv for a day if the captioning is still in customer menu then try to find a universal or replacement remote this remote may have dedicated captioning key there may be a button sequence on the front of the tv that will reset the customer settings
Dec 09, 2006 | Orion STV2763 27" TV
Memorex MT2025D TV Logo
48 people viewed this question
Top Memorex Televison & Video Experts
 Grubhead
Grubhead
Ekse
Are you a Memorex Televison and Video Expert? Answer questions, earn points and help others
