Hi, I recently purchased a used DMC-FZ7 Lumix. All pictures have vertical red and blueish lines accross the whole picture, far more visible on lighter backgrounds. I reset all settings to factory original but still have the same problem. Any suggestions?
looks like it may be ccd problem or loose connection, reset the camera with full charged batteries, light bang the camera with you hand at the base, do this with camera on
It's probably something to do with a lag or jam on your shutterspeed. so when you hit the button, and move you get a little blur. If its not this you might need to have your lens cleaned inside and out due to the camera zooms and catches the blurs on the lens after zooming so far in. I would recommend taking it to your local camera shop for adjustments and cleaning.
The date and time (and a lot more) are stored with every picture in its EXIF metadata. Any photo viewing/editing program should be able to display this data. To print this data, please consult the documentation for whatever program you're using to print your pictures. Depending on the program and printer you may print the date on the image, in the margins, or on the back.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or, despite what I said first, you can use any photo cataloging program such as iPhoto which is already on your Mac.
Hi, this appears to be ready for replacing. The button, I mean. It´s only mechanic, it breaks often. Go to a service shop, or send it there and let us know how you ended up with it. After that, enjoy your pictures :-) Vladimir
If the dot is not visible in print, but only on the camera's screen, the its only the LCD that is faulty.
If the dot is visible on screens and in print, then yes, it could be the sensor. Try taking pictures without the digital zoom. Chances are the dot is only visible with the digital zoom because the picture is interpolated.
If all else fails, you can try cloning out the spot in an image editor on the computer.
Windows: Try going to MY COMPUTER, and see if the camera is listed there. If it is, then double-click it, and open the sub-folder containing pictures. Then drag and drop them to another folder. ------------------------------------------------------------------------- Linux: The camera should appear on the desktop as: ***media. Double-click it, now the sub-folders containing pictures should open.
This is a CCD break down
Panasonic customer support is the place to go
If it is a recent purchase they will swap it
If it is older they may offer a discount on a replacement
