Turn the machine off and unplug it!
There are 3 10mm bolts around the door that need to be removed, the soap dispensing drawer needs to be taken out and you have 3 torx20 screws (one on the left and 2 on the right) that have to be removed. The bottom left corner of the machine there is a small door that you open, remove the hose that's clipped inside it, there is a small tab on the lower left, release the tab, pull open the door.
To take out the seal you have to loosen the 8mm bolt band clamp, and pull the seal off. Fit the new seal on until you hear it pop. and reverse the order.
Hope it works for you.
You need to wipe the seal down with vinegar. Mold needs water to grow. Have you looked at the bottom of the dishwasher after a cycle to see if you have standing water? While you are looking clean the filter.
