Watches Logo
Posted on Feb 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have a sport watch fossil CH2470. the second hand is not moving, stuck on 12, but everything else works. how do i fix this?
Arturs Kalnins
Level 3:
  • Master 2,338 Answers
  • Posted on Feb 28, 2011
Arturs Kalnins
Master
Level 3:
Answers
2338
Questions
9
Helped
1813011
Points
13579
Your watch is Chronograph watch and the big centre seconds hand is for chronograph function only - not day to day seconds counting. Check the small dials and you will see that the small seconds hand is already counting seconds- this small one is seconds counter. To engage chrono hand push the upper push button once. To stop it - push the same button again. to return to zero- push lower button. For users manual use this link: http://www.fossil.com/en_US/shop/customer_care/static/fossil-Instructions.html Rate me, please.
1helpful
I just recieved a tissot pcr 200 as a gift and the large second hand is pointed to 12 doesnot move the small second dial is working as are the hour and minute hand
your watch is a chronograph or stop watch. the large second hand that is pointed at 12, it is the second hand of the stop watch, it moves when you press te upper right button and it stop on that button too. when it stops the lower button is the reset. i hope i had been helped you.
4helpful
2answers
I have a big tic fossil watch. The flashing second is working properly, but the hand doesnt. It looks like slowing down. How can I fix this problem. Thank you
your watch has two batteries inside, the small battery is the one that had to be replaced. it is under the big battery, the small battery makes the minute and hour hand move while the big battery makes the seconds flashing. i hope that i had been helped you.
How to set or restart the fossil automatic ME 1030? Because the problem now is when the time turn at 12 at midnight, the date din turn..
sometimes during time set, the hands are set to change date at day time.
check it your date turns during 12 noon, if yes move the hands clockwise until you set your time and date on sync.
say you want to set your watch date:10th and time:10:15am
adjust your date at 9th
then move your hands clockwise until the date turns to 10th at the 12 thats the 12 midnight.
then continue moving your hands clockwise until you reach 10:15am
1helpful
When I reset the second hand, it stops at :54 instead of 12:00.
Go to "fossil.com" and at the bottom of the page select "customer care",
From the menus on the left select "watch instructions" and from the list of watches shown choose the one that suits yours watch and download the pdf file.
Second hand doesnt move. The ''stop watch'' second hand moves instead of the ''main'' second hand. also the stopwatch feature doesn't work. My watch is a Fossil Blue Titanium model TI-5071
Sounds like a job for Fossil!
Go to their web site "www.fossil.com" and at the bottom of their page is a menu which includes "store locator".
Feb 24, 2010 • Watches
6helpful
Where can i get extra links for a fossil watch
go to fossil web page tell them the seriel no on back of watch and they will send u the same ones
2helpful
Not sure what parts should be moving on new Fossil Me1020 watch.
I have a Fossil Twist ME1011, basically the same idea behind the one you have. What happens is there is a weighted third-circle that is in the back of the watch behind the battery (you can't see it) that spins a spring (the spring is the bottom seethrough part that ISN"T moving!) the spring then moved the UPPER seethrough part, which in turn spins the second hand!
IF the second hand stops working, carefully take the back off the watch and you'll see the weighted third-circle that I was talking about. It should spin, and in the middle there is a tiny flat head screw. The screw can get loose, so gently tighten it and the second hand should work again!
3helpful
Is there a easier way to change the month dial on a fossil
When you pull out crown, there is two positions (clicks), not just one. First click is for day/date quick setting. Second click is for hand setting. Pull the crown out slowly and carefully and you will soon find out both positions.
Rate, please.
3helpful
Fossil ch 2470 watch. I have no idea what the extra little dials are for on the face and how to set them. Please help
The dials are part of a Chronograph (stop watch) I assume there is a second, minute, and maybe a date function. Usually the large second hand is part of the stop watch on only moves when you start the stopwatch (top right button) push again to stop and reset back too zero is the bottom button. Usually to set or zero out those dials pull out the crown to the first click (also sets date) then push the top button to set the seconds (big hand) and the bottom button to set the other. sometimes you may need to pull the crown out to the second click (also sets hour and minutes) to set add'l dials. This is generally how you set most chronograph watches the button you push and what moves may be different.
Top Fossil Watches Experts
john h
k24674
ADMIN Andrew
ADMIN Andrew
Are you a Fossil Watch Expert? Answer questions, earn points and help others
