Apple iPhone 3G Logo
Posted on Feb 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I reset my iphone 3g and now its been frozen for 2 days, it only shows start-up apple logo. please help!
Anonymous
Level 2:
New Friend:
  • Expert 62 Answers
  • Posted on Feb 28, 2011
Anonymous
Expert
Level 2:
New Friend:
Answers
62
Questions
0
Helped
9352
Points
100
Do a hard reset.
  1. Press-hold the Home button (big circle below the screen) and the Sleep/Wake button (on top of the iPhone) simultaneously.
  2. Continue holding both buttons (Ignore the "Slide to power off") until the iPhone shuts off and begins to restart.
  3. You may let go when you see the silver Apple logo.
  4. You have completed a hard reset successfully.
  5. Don't be alarmed that it takes quite a while to load from the Apple logo to the main screen. This is normal.
If this does not work, put into recovery mode and restore from itunes.
Step One
Open iTunes and connect the iPhone to your Mac.
Step Two
Press and hold the Home button and the Sleep/Wake button at the same time.
Step Three
As soon as the screen goes black release the Sleep/Wake button. Continue holding the home button until you iTunes pops up a message telling you that it has detected an iPhone in recovery mode.
1351-500.pngThe iPhone will look like this:
Anonymous
Level 2:
New Friend:
  • Expert 50 Answers
Anonymous
Expert
Level 2:
New Friend:
Answers
50
Questions
0
Helped
8016
Points
157
Try resetting using DFU mode. To enter DFU, make sure your iPhone is plugged in and powered completely off, and iTunes is running. Then do the following three steps: 1) Hold down the power button for 3 seconds. 2) Keep pressing the power button, and in addition hold down the home button for ten seconds. 3) Release the power button but keep holding home until iTunes notifies you that your iPhone is in recovery mode. The screen of the iPhone should be black. Then just hit restore and it should work. If this doesn't work, then you have a hardware issue (possibly logic board failure) and you should go to apple to get it fixed.
Unfreeze my iphone
Reset it with the home and power buttons until it shows the apple logo. If not, put it in DFU mode, but it will erase everything you have.
2answers
Frozen touch pad
I had the similar problem. Found this suggestion on the web to reset iPhone 3G to it's original settings. You may have to restore your media and data files after resetting. It's the only way out for me since I can't get beyond the "Apple Logo" thingy, and I am too lazy to bring it down to the Apple Store.
Try this:
1.) Shut down the iPhone 3G.
2.) Start up iTunes
3.) Hold down HOME button on the iPhone 3G
4.) While keeping the HOME button depressed, plug in the Sync cable
5.) A message will pop up to ask if you want to reset.
6.) Just click YES and the reset process should start.
Thank
Good luck.
I tried to upgrade my Iphone and I did not do it. Now I can not use it. I tried to restore and show me and error.
Download the latest iTunes to your computer and reset the iPhone. Then re-sync it.
Reset
To reset iPhone, press and hold the Sleep/Wake button and the Home button at the same time for at least 10 seconds. During this time, a red "power off" slider may appear and the screen may go black, but do not release Sleep/Wake and Home buttons until the Apple logo appears.
If iPhone won't turn on, or the display freezes or doesn't respond
  1. Press and hold the Home button for at least six seconds, until the application you were using quits.
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a 10 seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
  3. If that doesn't work, reset iPhone. Press and hold the Sleep/Wake button and the Home button at the same time for at least ten seconds, until the Apple logo appears
More resets:
Try This:
1. Remove Sim Card
2. Hold in 'Home' button and 'On/Off' button together until Apple logo appears
3. Replace Sim Card
4. Hold in 'Home' button and 'On/Off' button together until normal phone screen appears.
Also, Try this:
2.) Start up iTunes
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Happy Holidays!
Thanks, Joe
I’m happy to assist further over the phone at https://www.6ya.com/expert/joe_8b8c2cd6ce148309
We did a reset on the phone now it is frozen
Sometimes, the iPhone 3G gets so frozen that the standard force quite process for program doesn’t work. In that case, you’ll need to reset the iPhone.
To do that, hold both the sleep/wake and Home buttons together for at least 10 seconds.
The red shut down slider will show up at the top of the screen and then disappear. Keep holding the buttons. The screen may even go black, but don’t let go of the buttons until the Apple logo shows up. When it appears, let the buttons go and the phone will start up normally.
23helpful
3answers
Frozen jailbroken iphone 3g
I'll recommend you re-break your phone and if you are willing to perform the task in a more simple yet time-saving manner, follow the step by step guide from this website: iphoneunlockeasily.com
42helpful
Why wont my iphone turn on???????? please help!!!!
Try these resets:
Reset
  2. If that doesn't work, turn iPhone off and turn it on again. Press and hold the Sleep/Wake button on top of iPhone for a few seconds until a red slider appears, and then slide the slider. Then press and hold the Sleep/Wake button until the Apple logo appears.
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
2helpful
My Iphone 3g 8gig is stuck on the Apple logo
Try each of the following resets:
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Thanks, Joe
1helpful
My iphone is frozen after i restored it how can i solve this problem
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Thanks, Joe
2helpful
Logo is frozen and the phone cannot be used.
Here are several resets you can try:
Reset
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Thanks, Joe
11helpful
2answers
My iphone 3g is frozen on the apple sighn how can i fix? it i already tried to reset it on itunes but it sais there is an eror pleas help me....
More resets:
Try This:
1. Remove Sim Card
3. Replace Sim Card
Also, Try this:
2.) Start up iTunes
Thanks, Joe
Top Apple Cell Phones Experts
Grand Canyon Tech
Grand Canyon Tech
ADMIN Andrew
ADMIN Andrew
Paul Bade
Are you an Apple Cell Phone Expert? Answer questions, earn points and help others
