This is my problem:
(Canon Pixma 3000) -5 flashes amber means the print head is not installed properly (error code 1401) or the EEPROM data of the print head is faulty (error code 1403 or 1405).
Make sure the contacts on the printhead are clean, re-install and try again. If this fails a new printhead may be required. You may be able to re-initialize the EEPROM by entering the service mode
Question: how can I enter the "service mode"? Then what shall I do?
Frank
The print head is not installed [1401], or it is not properly installed (Print head temperature sensor error [1403] / Faulty EEPROM data of the print head [1405]).
If you wish to get more details about this; visit the site linked here; after an hour.
This is consistent with any of error codes 1401, 1403 and 1405. It indicates a problem with the print head.
Per Canon the resolution of these errors 'requires the assistance of a Canon authorised service facility. Please use the link at the top of the page to locate your nearest facility.'
From Canon error page for 'Orange light blinking 5 times':
1401/E05
Description: The print head is not installed or has not been properly installed.
1403
Description: A print head temperature sensor error has occurred.
hello this error means that the EEPROM data of the print head is faulty so is a problem with the print head, Install the print head properly,and close the access cover. Or, with the print head installed, turn the printer off and on, i hope it will help And please check the below link to get the service manual for ip4000 it will be helpful: http://goo.gl/Edjmh
This error is the print head is not installed [1401], or it is not properly installed (Print head temperature sensor error [1403] / Faulty EEPROM data of the print head [1405]).
5 times
The print head is not installed [1401], or it is not properly installed (EEPROM data of the print head is faulty) [1403 / 1405].
Install the print head properly, and close the access cover.
Or, with the print head installed, turn the printer off and on.
This might help
