You have two options. If your Aspire has an HDMI port, the easiest option is to use an HDMI cable between your TV and Computer. There are many HDMI adapters available if your TV doesn't have an HDMI input. After Connecting the HDMI between your TV and Computer you will need to change the input of your TV to the correct HDMI input.
The Second option is to use an VGA Cable. Most new TVs have a VGA or RGB input. Connect the VGA cable between you Computer and TV and Change to the RGB input on your TV. You can also use a 3.5mm audio cable between your laptop and TV for sound.
Hi
Have a read of this it may help
http://www.ehow.com/how_4457043_connect-pc-hdmi-tv.html
please let us know if it helped you
SOURCE: how do I connect Acer Aspire One to sony bravia tv?
If your Aspire One has a VGA out port,
Then use a VGA cable to connect to the PC IN on the TV.
SOURCE: Is it normal for my
its not normal for any laptop to make lots and lots of noiseeeeeeeeeeeeeee
SOURCE: how do i take out the hard drive on a acer aspire
turn off the notebook
make sure all the cables are disconnected
flip the laptop
on the bottom look for a compartment
the compartment has a picture of stack of 3 cds,like circles
remove the screws of the compartment
look for a silver or a black colored box(hard drive)
remove the cover on top of the hard drive
take the hard drive out carefully
when you replace it make sure everything is kept correctly
SOURCE: is there a manual on
Yes there is. Below is a link for your user guide and quick start guide. There are also application and driver tabs on this same page. Book mark it for future reference, it is a very useful resource.
http://us.acer.com/ac/en/US/content/drivers
Click on the link to download the manual of your choice. Click on the tabs to see what is available in drivers or applications, again, for future reference.
I hope you found this information useful. If so, please remember to leave positive feedback.
Thank You,
Brian
