Samsung Prostar DCS Phone Logo
Posted on Feb 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
We have a old message for after hours calls and can't figure out how to change it.
Anonymous
Level 2:
Director Badge:
Uploaded 100 video answers.
  • Expert 213 Answers
  • Posted on Mar 07, 2011
Anonymous
Expert
Level 2:
Director Badge:
Answers
213
Questions
0
Helped
99957
Points
265
I assume that your message is on Voice mail, if this is the case , dial into the VM via the night VM key (where the night messages are stored), enter the passcode then dial 0 - 5 - 7 then 3, record the new message then press the # key to store, hopefully this will help, I've sent a clip from http://www.abbeytelecom.com .
Im looking for manual for a one tel magma 100.
You can try to fill up this form and check the availability of the manual. They may send it to your email if found available.
https://www.2instructions.com/search.php?cmarque=ONE.TEL&modele=MAGMA%20200
Old Casio Work Out 879 / JC-10 Forgot how to change time for alarm feature. Finally figured out how to shut alarm off.
Press and hold top left button. hour will flash. use bottom right button to change hour. press top right to change to minutes. use bottom right button to change minutes.
May 05, 2011 • Watches
Cannot figure out to set answering machine on my vtech, I recevied as gift.
Turn on the answering machine by pressing the on/off button on the base. Set the time and date by pressing the Time/Set button (to the right of the menu button) and pressing Change until the correct day or time is heard. Then press Time/Set again.
To record a message, press Menu until you hear "Set Outgoing Message", then press Record and speak the message (include the mailbox info if you are using them). Press any Play/Stop button to end the message.
Set the various features by pressing Menu to access each one, then press Change to change the setting. Press Time/Set to lock in the change and press Menu to change the next feature. Press a Play/Stop key to leave the menu.
The most important one is "Set Announce Only" to Off for callers to leave a message.
All messages will go into Mailbox 1 unless the caller indicates a different mailbox. Press the Mailbox button to hear new messages if the mailbox has a mix of new and old messages. Press the button a second time to hear all messages. Skip/Quick lets you advance to the next message and Repeat/Slow will let you hear a message again.
Press Vol (up) to adjust the base speaker volume higher during playback.
In the menu, the first option lets you set the two digit security code to access the messages when you call in from another phone. When calling press # followed by 1, 2, or 3 to access the desired mailbox. Press #4 to repeat a message. #5 to skip. Press *0 to end the remote call.
For the full manual, see: http://www.vtechphones.com/vtechphones/index.cfm/support/manuals/ and scroll down to 5866.
I hope this helps.
(all this assumes the base is on (connected to power) and connected to a good phone line. Without power it will not work at all. I test phone lines for dial tone with an old corded phone.)
Outgoing voicemail message won't change
You need a technician on-site to review the voicemail system programming and make the necessary changes.
1helpful
WE NEED TO CHANGE THE INTRODUCTION MESSAGE WHEN THE OFFICES ARE CLOSED, IT SHOWS THE NEW MESSAGE WHEN YOU LISTEN TO THE REVIEW THE MESSAGE, BUT ITS THE OLD MESSAGE YOU GET WHEN YOU RING OUT OF HOURS ON...
Hi, this sounds like you have done everything right, are you sure that you are going into the night message VM box? I have uploaded a video explaining Voice-Mail, go to http://abbeytelecom.com for more like this
I would like to change the after hours message on the phone. I go to the mailbox management and then to change the no answer greeting. I have changed and okayed the new message. When I then call from an...
This requires you knowing where the messages are stored. start with the model number of the VPS, and a proper interface cable to the unit.
In a TVS it requires hyperterm and a serial cable, in a TVA it needs a USB cable and the software.
BTW we delete that Welcome prompt, along with the Good (morning/afternoon/evening) prompts and go straight to custom service menus. It's in the back of the manual in one of the appendices.
Carl
Cant recieve text messages on at&t motorola c168i
there are a few reasons that could be causing this.
1. You may have changed the message center routing number.
* Go to messages - options - message setup - text messages - profile - SMS settings(should be check marked, if not select activate) - Customize
* The message center number should be +13123149810(plus must be entered....hold 0 key for plus)
2. Text messaging pay per use has been taken off your account. dial 611 from your phone or 1-866-246-4852 (after hours call 866-801-3600) from another phone for customer service. request pay per use to be added to your phone, or purchase a messaging plan.
These should cover it. Make sure to power you r phone off and on after any changes.
4helpful
2answers
Message tones and vibrate facillity
To change the vibrate function:Go to main menu, phone settings, phone profiles, highlight the 'normal' one & press the 'options' soft key to the left of the touch screen keypad. Pick 'edit', then the 'call alert type' will be highlighted. Press the left soft key saying 'options' & select 'change'. You can then opt for it to vibrate by highlighting the vibration one & pressing the tick on the touch screen bit. Then don't forget to save the changes!
To Change the ringtone:
  1. From the standby screen, press Menu (Figure 1).
  2. In the main Menu, press Settings (Figure 2).
  3. In the Settings menu, select Phone profiles and press (Figure 3).
  4. You will be presented with a list of phone profiles for different situations and environments. The one you're currently using will be ticked. Highlight the one you want to use (in our example, Normal) and press the Edit button at the bottom of the display (Figure 4).
  5. You are taken into the profile settings (Figure 5). At the top of the list you'll notice three tab icons - these represent (from left to right), ringtone, message alert, and keypad sounds. You can switch between settings for these by tapping one of the tabs.
  6. You should be taken first into the ringtone settings list. Should you want to change the Call alert type (from melody to vibration then melody, for instance) tap this option and scroll through the list of options to choose the one you want.
  7. To change the Voice call ringtone, tap this option on the screen. You will be taken into a list of phone file folders from which to choose your ringtone (Figure 6). You can tab across to view files stored on a memory card, if you have one installed.
  8. Press the Sounds option. You now have the choice of choosing from yourMusic files, Ringtones that are loaded onto the phone, or My voice clips(clips you have recorded) (Figure 7). You can select from whichever of these folders you want - the setting procedure is the same for each. In our example, we'll choose from our Music folder to select one of our tunes as the new ringtone.
  9. Press the Music option. A list of tracks appears (Figure 8). Tap the one you want in order to highlight it (Figure 9). Press Options, then tap on theSelect menu option to install it as your ringtone (Figure 10).
  10. You are now taken back to the Normal profile settings, where the Voice call ringtone has changed (Figure 11). To save this change, press Options and then Save (Figure 12). Alternatively, press Back and you will be asked whether you want to Save?. Press Yes.
In the ringtone settings menu, you can also change the video call ringtone (which is lower down the menu) by following the same procedure.
Top Samsung Lands Phones Experts
Ngoro
john h
ADMIN Andrew
ADMIN Andrew
Are you a Samsung Lands Phone Expert? Answer questions, earn points and help others
