Question about Panasonic LUMIX DMCZR3 DMCZX3 Digital Camera
How do i upload my video to my comp? - Panasonic LUMIX DMCZR3 DMCZX3 Digital Camera
    New Friend:
Hello :)
  1. You shall connect your camera to the PC, via the USB cable which was in the box with your camera. Be sure to use a battery with sufficient battery power.
  2. Next press the up and down arrows, on your camer,a to select "PC" as USB mode. If it is already set to "PC", the camera will be automatically connected to the PC, wiithout displaying the "USB mode" selection screen.
  3. Go to "My Computer", and double click on "Removable Disk"
  4. Double Click the "DCIM" folder
  5. Your videos are there, along with your pictures. Just copy and paste them to a folder in your hard disk drive
Posted on Feb 28, 2011
6ya staff
SOURCE:
I can't upload photos from my nikon coolpix s210...
its easy to upload your photos..first store all the photos in your desktop which makes it a faster process to upload..(upload using picasawebalbums)..coming to your problem did you try to do the same in some other computer..if its working in some other comp, the check your usb in the comp.try to connect it to other usb hubs nd check it out..
May 22, 2009 | Nikon Coolpix S210 Digital Camera
How to upload vid fro easyshare m863 to comp?
If you are not able to find your connecting cable. and i am assuming your need is to transfer the data to comp. Well what you can do is you can take out the memory card and fix it into the card reader (you will get a card reader vey cheap anywhere.). and connect it to your comp. Now your card will work as a flash drive and you can transfer data easily then... Hope this helps you out.. :)
Mar 09, 2009 | Kodak EasyShare M863 Digital Camera
Trouble uploading photos onto new comp.
Consider NOT connecting your camera to your computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Jan 06, 2009 | Pentax Optio M10 Digital Camera
Bought disney pix micro camera wont upload pics to comp
Put the media card into a USB card reader on the computer.
May 15, 2017 | Digital Blue Disney Pix Micro Digital...
Receiving error messages when uploading images and videos to comp
Uninstall the software
Flush your registry of all references to cybershot or whatever your program is called.
reinstall software and see how you go
Dec 01, 2008 | Sony Cyber-Shot DSC-T5 Digital Camera
JVC gr-d70 connection / uploading
wrong connection! you must use firewire to stream video and audio from your cam-make sure comp has connection-called 1394-on cam it's called dv and get proper cable and you will be fine-usb only for pics
May 23, 2008 | JVC GR-D70EK Mini DV Digital Camcorder
When I upload video into my computer, I get picture, but no audio.
Make sure the recommended viewer supplied by the camera manufacturer is installed. If it is reinstall it
Mar 19, 2008 | Samsung Digimax S630 Digital Camera
Uploading
if u have given data cable with that ... connect it to comp and and also if needed install the given disc installer tooo...
Dec 26, 2007 | Audio Players & Recorders
New comp
Which OS is running on your computer.
Sep 29, 2007 | Compaq Diskette Drive / Cd-Rom Cable...
Panasonic LUMIX DMCZR3  DMCZX3 Digital Camera Logo
114 people viewed this question
Top Panasonic Cameras Experts
Ekse
rajiv6089
Level 1 Expert
Are you a Panasonic Camera Expert? Answer questions, earn points and help others
