It sounds like the rechargeable battery is no good, if the battery can be removed then it is worth fixing, but if the battery is built in replace the bluetooth device.
Try and find a similar charger and test the device on that. if you have the same results than either the battery in the device is completely dead, or the device itself has malfunctioned and needs to be repaired/replaced. if the device is still under warranty you can try and contact the manufacturer for help or a repair/replacement.
