Hi ricevans,
Check to make sure that the filter in the pump is not clogged. Open the little door on the bottom and have a towel ready as there will be some water in the pump. Turn the dial slowly and let the water seep out. Pull out the dial and if you see any kind of debris, (lint, coins, etc..) Clean out all of this and put back into place and your machine will work fine. The reason for this is that the pump is designed to pump out all the water in an 8 min cycle if it exceeds the time limit the machine just stops. Hope this helps you out.
