How do you remove broken 2460 washer motor
Am not sure of whether washing machines spins or not. But would like to help in either way of the problem
If it doesn't spin or pump water
If your
washer doesn't spin or pump water out but the motor is running, your
washer probably has a frozen pump pulley. If so, you need to replace
the pump. To check the pulley, remove the pump from the washer and try
to rotate the pulley manually. If it doesn't turn freely--if it's
frozen or stiff--replace it.
If it spins, but doesn't pump water
If your
washer spins but doesn't pump the water out, the drain line is probably
clogged. In many washers, a small sock or other piece of clothing can
get between the clothes tub and the outer tub that holds the water. If
the clothing gets between the tubs, it may then get into the drain hose
that's attached to the pump--or even into the pump itself. If it's in
the pump, you need to remove the hoses from the pump and pull the item
out.
To remove the sock from the outer tub port, open the
washer's main access panel and remove the large-diameter rubber hose
that connects the pump to the bottom of the outer tub. Then, using
needle-nose pliers, try to grab and remove the clothing through the
port.
Sometimes you can't remove the stuck clothing from
below. Then you have to remove the agitator, top of the outer drum
shield, and inner clothes tub. This isn't easy to do--and you may need
special tools--so you might be happier getting a qualified appliance
repair technician to do the job.
If the drain line isn't
plugged, the problem may be with your pump. Even if the pump appears to
be turning, the internal impeller may be broken. If so, you need to
replace the pump.
Credit to chad fix it
runs, spins but does not drain
When I read this I decided my Sanyo ASW 40AP must not have a faulty water pump, and sure enough, some further probing revealed two bra wires and a mass of twisted cotton strands. Good as new!
my machine will not drain
