Philips Magnavox 27MS343S 27" TV Logo
Posted on Feb 28, 2011
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
When i turn on my tv, the screen has like rainbow color all over it. i found out if you hold a magnet up to the screen, the color moves if you move the magnet. no picture of anything,,just color i would like to fix this problem, please give me some information on how to fix this.
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Feb 28, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
7774
Points
6
To fix this, you need to do something called degaussing. You should keep magnets away from the screen in the future, because they cause this problem.
The first thing to try is to turn it on and off, making sure that all magnets and speakers (which have magnets in them) are kept far away from it. This will activate the monitor's auto-degausser if it has one. If this does not help, this guide: http://www.wikihow.com/Degauss-a-Computer-Monitor gives a couple solutions, including using a soldering gun (not a soldering iron), illustrated in the video below:
With a powerdrill:
Or investing about 60 bucks in a degaussing coil like this which is a guaranteed fix:
One other trick that might work is to take an old CRT monitor ("fat-screen" rather than "flat-screen"), hold it up to the tv screen to screen, and turn it on and off to have the monitor use its own degausser. The monitor may have a button to activate degaussing, or it may be in the menu you can bring up with the buttons on the bottom of the screen.
If you don't want to deal with any of this, a tv repair shop will degauss your tv for you quickly.
Rick Arnold
Level 2:
New Friend:
  • Expert 80 Answers
Rick Arnold
Expert
Level 2:
New Friend:
Answers
80
Questions
0
Helped
22522
Points
233
The TV probably needs to be degaussed. Some places sell a degaussing tool or some devices have a built-in degausser. Non-magnetically shielded speakers sitting on or around the TV can cause this. Such as basic CD Stereo speakers.
Picture tube
yap! for CRT TVs with ring of colors, do the following to solve the problem; find a normal magnet from a retired speaker , just switch on the TV and while the TV is On, hold the magnet about 15CM from the screen while moving it arround the whole screen area. when it starts to degause/to be clear just move the magnet around the screen while moving further away from the TV screen let say 20CM, 25CM , 35 cm etc.
My magnovox tv color looks like a rainbow
it needs to be demagnetized, do you have anything setting close by that has a strong magnetic field ? if so move it away.
2answers
Rainbow screen aiwa tv,, screen shows different colors like rainbow// brushing a magnet infront of the screen fixes the issue temporary
Picture tube is magnetized. Manual degausing is required. already you have done this.
Since you say it is reappearing, you have to check the following.
1. Relocate the TV or relocate if you have placed any tower speakers
or home theater speakers close-by.
2. Check whether auto degauss functioning OK. In the MENU
check whether you switched off auto degauss option. If it is OFF
enable it to ON.
3. Finally re orient the direction of your TV and watch the rainbow
effect. Switch OFF TV, wait for 20 mts, and again switch ON.
Repeat the process. It should disappear.
Magnetic toys or any other devises using magnet will cause this problem.
Rainbow on bottom of picture .it is blue in color.
Most likely to be caused by a strong magnetic field. Move any/all stereo speakers, subwoofer, AC power adaptor, or other magnetic radiating object away from the TV. Sometimes the magnetic source will leave some residual magnetism in the metal parts of the TV, but that will clear if the TV is turned off and allowed to cool before turning back on.
Colors out of alignment
you moved this set huh? alignment is out, magnets slid out of place on align coils the a convergance alignment preformed (sometimes u get lucky and the coils can be put back perfect and then no alignment needed)
Has rainbow lines on tv screen
shadow mask is warped. tv might have been dropped. crt is bad(picture tube). try deguassing it. if you dont know what that is take it to your local service center. the rainbow effect is a magnetic field of some sort. try unplugging and move to a different location. could be a speaker too close to tv.
1helpful
My tv is turning everything purple like it is
Hello :
The problem is your color purity is off. The earths magnetic poles cause this to happen on all direct view televisions, when you move a television or turn it from its usual viewing spot. You may have noticed a thump sound when you first cut on the television after its been off for a while, this is the televisions degaussing circuit mixing the color phospers in the picture tube. One way to clear this is to turn off the set for at least 20 mins and turning it back on this usually clears the purity. Have you ever had a older computer monitor and it had a button on it that says degauss an press it and you see a rainbow of colors then the screen goes back to normal. Well your television also has one too but does it when you first cut on the television you can't see the rainbow effect because the screen is still dark at this point.
If this does not work have a technician come out and degauss the set for u manually, using a degaussing coil.
Hope this explains your problem,,
Please leave a comment for futher assistance.
[email protected]
3answers
I have samsung 21 green screen
Either something wrong with the picture tube or something with scart input if you use one. / / David
TV Colors gone like a rainbow
It's dignostic coil problem replace it
or moving maganent on screen when colors have gone
2answers
Tv rainbow in screen
The picture tube has become magnetized, possibly by someone getting a magnet to close to it. You can de-magnetize it using a strong magnet (cow magnet or similar). Place the magnet as close the the screen as possible without touching it to the screen. Starting at the middle of the screen and slowly (not too slow, about one full circle per second should do) move the magnet in a circular motion. With each full circle move the magent twards the outside (making a larger circle) as well as moving it farther away from the screen. Using a magnet will not harm the screen, so play with it and you'll soon get the feel and will see what you need to do.
Tv's have a circuit built in to 'Degauss' (demagnetize) the screen each time you turn it on, but this will only work if the set is 'Cold'. If the set is left off for 2 hours (to cool doen) and does not demagnetize when you turn it on the circuit is faulty.
Top Philips Televison & Video Experts
matt martin
matt martin
Grand Canyon Tech
Grand Canyon Tech
Are you a Philips Televison and Video Expert? Answer questions, earn points and help others
