Need Help cisco 1841 router with serial port connected to v.35 adtran exprees 6540 terminal with 2 mb lease line.
lease line ip isp WAN Interface Address: 202.146.80.45/30 (255.255.255.252) Customer WAN Interface Address: 202.146.80.46/30 (255.255.255.252
IP Address Block Allocation Customer Own IP Address Block/CIDR/Mask: 58.71.152.128/28 (255.255.255.240) DNS Server Primary : 58.71.132.10 Secondary : 58.71.136.10
i setup the serial connection with customer ip and subnet
the link is up on serial connection. but when i run the test connection it cant ping the dns, error isp ip adress and dns not correct. the encapsulation : Hdlc
Have spent about 2 long days but no luck, do I need to setup the routing and nat
Thank you for your prompt reply,sir These values were given to me by the isp on the serial connection what wan ip do i use the isp wan ip or the customer wan ip. thank again for you help appreciate it p/s do you think the isp made a mistakeThank you for your prompt reply,sir
Cisco router tech support phone number at 1877-778-8@9@6@9 in USA and Canada. Our technician’s organizations are additionally splendid and suitable that gives us best service and helps you want. Click Here For Tech Support:https://goo.gl/T2bgVyCisco router tech support phone number at 1877-778-8@9@6@9 in USA and Canada. Our technician’s organizations are additionally splendid and suitable that gives us best service and helps you want. Click Here For Tech Support: https://goo.gl/T2bgVy
You can't post conmments that contain an email address.
Re: cisco router 1841 connected to serial interface
Hello, Theres no need to setup for the nat but please check the wan interface and subnet mask ip it has to something else and not 255.255.255.252..Try 255.255.255.240 it must work...
Yeah probably the mistake is in the connection set up ,So you need not set up routing and nat..If possible please Get all the address From your ISP..That will surely solve your problem...Thank you!!...
Regards!!!...
Regards!!!...
Try also calling your ISP technical help line and go through settings, they can also check online if there is anything wrong on their side of the fence, what is your ISP by the way?
The value is not necessarily wrong, but 255.255.255.252 is 11111100 , that means you have only 2 bits available to define IPs, with that mask IPs will range from 0 to 4. Did you already call your ISP tech help phone to verify settings? We can find out more if you provide info on your ISP and your location.
More, if you get "error isp ip adress and dns not correct", then also dns are not correct. If you need to set up serial connection you should use the IP needed to conect with router via serial connection, then I assume you use host IP. Ift will be easier if you provide required details, also mention if you have more than one router
Serial interface connected DCE and which DTE CISCO cable to another router, and in settings you put second router IP, if you have only one router it is strange you need to set up serial connection. If you are using the router to establish an ordinary broadband connection to an ISP, the mask should be 255.255.255.0.
You configure serial connection if you have
Normal
0
false
false
false
MicrosoftInternetExplorer4
/* Style Definitions */
table.MsoNormalTable
{mso-style-name:"Table Normal";
mso-tstyle-rowband-size:0;
mso-tstyle-colband-size:0;
mso-style-noshow:yes;
mso-style-parent:"";
mso-padding-alt:0in 5.4pt 0in 5.4pt;
mso-para-margin:0in;
mso-para-margin-bottom:.0001pt;
mso-pagination:widow-orphan;
font-size:10.0pt;
font-family:"Times New Roman";
mso-fareast-font-family:"Times New Roman";
mso-ansi-language:#0400;
mso-fareast-language:#0400;
mso-bidi-language:#0400;}
Serial
This is more of a business unit. It requires a serial port connection and a fair amount of CISCO networking engineering knowledge. It is command only. No GUI interface.
The Cisco 1841 router is designed for secure data connectivity and provides significant additional value compared to prior generations of Cisco 1700 Series routers by offering more than a fivefold performance increase and integrated hardware-based encryption enabled by an optional Cisco IOS Software security image.<br /><br />The <a href="http://www.router-switch.com/cisco1841-p-97.html">Cisco 1841</a> dramatically increase interface card slot performance and density over the Cisco 1700 Series while maintaining support for more than 30 existing WAN interface cards (WICs) and multiplex trunk cards (voice/WICs [VWICs]-for data only on the Cisco 1841 router).<br /><br />The <a href="http://www.router-switch.com/cisco1841-p-97.html">Cisco 1841 router</a> offers embedded hardware-based encryption enabled by an optional Cisco IOS Software security image; further enhancement of VPN performance with an optional VPN acceleration module; an intrusion prevention system (IPS) and firewall functions; interfaces for a wide range of connectivity requirements, including support for optional integrated switch ports; plus sufficient performance and slot density for future network expansion and advanced applications as well as an integrated real-time clock.<br /><br />Cisco 1841 router Product Details<br />Product Description Cisco 1841 router<br />Device Type Router<br />Form Factor External - modular - 1U<br />Dimensions (WxDxH) 34.3 cm x 27.4 cm x 4.75 cm<br />RAM 128 MB (installed) / 384 MB (max) - SDRAM<br />Flash Memory 32 MB (installed) / 128 MB (max)<br />Data Link Protocol Ethernet, Fast Ethernet<br />Network / Transport Protocol IPSec<br />Remote Management Protocol SNMP<br />Digital Signaling Protocol ADSL over ISDN<br />Features Cisco IOS IP Broadband , firewall protection, 128-bit encryption, hardware encryption, VPN support, VLAN support, Intrusion Prevention System (IPS), 256-bit encryption<br />Power AC 120/230 V ( 50/60 Hz )<br />System Requirements Microsoft Windows 98 Second Edition<br /><br />P.S. If you would like a new sealed Cisco 1841, the competitive price offered at RouterSwitch.com is US$586.00 per. Visit Cisco 1841 to see more...<br /><br />Notes: Router-switch.com is a World's Leading <a href="http://www.router-switch.com/">Cisco Supplier</a>, founded in 2002. It sells new, used and refurbished Cisco network equipment including Cisco routers 800/1800/1900/2800/2900/3800/3900 series, Cisco switches, Cisco Firewalls Security, Cisco IP Phones VOIP, etc.<br /><br />
The Cisco 1841 Router has a single, external compact flash memory. This is the only flash memory for the system and should never be removed whenever ROM Monitor (ROMMON) is being updated with a new image or configurations or when the compact flash LED light "busy" is on.
When using Public IP addresses on one interface, usually facing your ISP, and using Private IP addresses (AKA RFC 1918) on another interface, usually facing your LAN, one needs to utilize network address translation (NAT) in order to connect LAN computing resources to the Internet.
Cisco has a fantastic article on how to perform the necessary procedures on their web site.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_configuration_example09186a0080093f8e.shtml
cisco routers make use of an IOS software for configurations.
you have to connect the router to a computer system through an hyper terminal program in order to access the router command interface,there is no way you will be able to configure this router without having cisco configurations knowledge.
the steps could be complex/complecated for a novice.but all the same,
after running the hyper terminal program on your computer to connect the router(start-accessories-communication-hyper terminal) make sure you use cisco serial cable or a cat5e roll over cable.
press the enter key once and type 'enable' then press enter,
configure terminal,to take you to a global configuration mode.
i will advice that you should contact a cisco person in your area for help
It is possible if the IOS on your router supports the necessary dialing features. You'll need to use WIC-1AM analog modem modules (or similar) in each router. A cheaper alternative would be to use standard desktop modems...the serial ports could be connected to the Aux interfaces on the routers. Good luck...and I hope this is helpful!!
1: Would a Cisco 1720 provide a simple soltution for terminating a T1 to
Ethernet 100 Mps
I recommend a 1721
2: If this would not be an option, what Cisco box would provide the needed
termination/routing
I recommend a 1721
3: If a Cisco device could do this would it be necessary to replace them at
both locations or could it communicate with the Adtran device.
It depends on the topology of how your sites are interconnected to each
other. Please describe in greater detail.
