The memory card may be physically locked. If you remove the memory card from the camera look at the side of the card. There is a small lock that can be slid up and down on the side of the card. Make sure the lock is off. If you cannot tell which direction is locked switch it and then try it in the camera.
If you have pictures on the card try to download them with a card reader first then attempt to format the card in the camera by going into the camera menu.
With the SD cards label pointing up, look for a small slider switch on the side of the SD card. Here is an example:
Move the switch in the opposite direction.
Please let me know if I can further assist you.
Regards,
KYTechnology
