Toshiba 37AV502U 37 in. LCD HDTV Logo
Posted on Mar 01, 2011
Lost my remote. I changed rooms now when I hit the power it goes to the inital home screen and I can't get it to go off.
Anonymous
Level 1:
New Friend:
  • Contributor 4 Answers
  • Posted on Mar 01, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
2353
Points
13
Are you sure you are pressing the Power button, and not the Home button?
1helpful
How do you program a universal remote to a model 6420FF Sylvania TV?
Code search. Hold down code search button until on-off light flashes then stays lit. keep pressing the on-off button until the power to your tv goes off, then hit the enter button. your remote should be set to your tv!
I have a brand new Aquos 52" LED TV and I accidentally locked remote operation and THEN found out the front touch screen panel was broken. Any way to manually reset the TV or remote to gain access to...
While the set is turned on, you need to hold the power button until the set shuts off and the led in the middle of the bottom flashes once. Then quickly release the power button and press the vol - and input buttons together along with the power button. Your TV should then turn on and should show you a blue box with the letter K. Now press the vol- and channel- buttons at the same time. You should now be in the service menu. With your remote arrow up until the top line says industry init. Arrow to the right and hit enter. Screen should turn green and say factory init success. I hope this helps you.
Orion TVD2710. Lost remote, can't change signal input
I would suggest you try to find a universal remote that has an "input" or "source" button and program that one to your tv. By pressing the "source" or "input" button, it will change the input to the tv. I hope this helps! -Der Strom
Lost remote, blue screen
Sounds like you're stuck on..... Video 1 or Video 2 (whichever). If you can access your TV's menu at the front panel, you should be able to switch over fairly easy. Hit MENU. Using your VOLUME UP & DOWN buttons, Go to CABLE/SATELITE/ANTENNA, hit VOLUME UP or DOWN 'til it switches back to TV picture then hit ENTER. If you do not have an access panel in front but possibly have any other remote (cable or satelite or home theater, etc...) that can be paired with this TV and has an INPUT button, you can change the setting that way.
Hope this info was helpful. Good Luck!
7helpful
The tv quit responding to the remote
On this unit if you do a fact reset it should fix this problem steps as follows. PS you might need 2 people
1- unplug power cord from back of TV
2- on the key pad on the tv hold the input and vol dowm buttons
3- while holding the buttons plug the tv in, keep holding the buttons until the screen comes up.
4- once the screen is up there should be a white K in a blue or green box.
5- next, on the key pad on the tv press the channel and vol down buttons once.
6- a menu should pop up
7- using the sharp remote,locate the directional pad
8- press the down button once should bring you to a 2nd page
9- top should state FACT INIT press the right arrow once to turn on, next a series of back slashes come up.
10- screen goes green and says INIT Successful
11- unplug power cord from back of tv wait 10 sec then plug back in. tv should turn on by itself. should be back to as new.
6helpful
Remote does not work for Sharp lc42d85u
1- unplug unit from back of unit
11- unplug unit from back of tv wait 10 sec then plug back in. tv should turn on by itself. should be back to as new.
If you get to step 7 and the remote still does not work then you need to replace the ir sensor board (aka) LED unit per Sharp.
if needed here is the orignal part info DUNTKE868FM01 about $12.00+ tax
10helpful
2answers
ERROR E001 & E004 PCR-T470
Hi.
You have performed the flag clear incorrectly and now the machine is trying to do an entire RAM clear. You may have already lost everything. Make sure you do not type any numbers while it is like this.
Try this:
Turn key to PROGRAM mode.
Turn power off at wall.
Hold FEED down.
Turn power on at wall.
When you see '0.00' on display, let go of RECEIPT FEED.
Press SUBTOTAL
3answers
Panasonic SA-HT930 "INIT" Message
I have that problem after an electrical short out.. wow, nobody knows how to solve it?
I hope somebody can fix this problem
53helpful
14answers
Sharp Aquos LC-42D62U VOlume Control
OK guys I'll save you. The tv is in hotel mode. To get it out from there you have to go in service menu but DO NOT CHANGE ANY OTHER THING IN THERE, only what i tell you. With the tv on and the K letter on the screen press in the same time vol- and ch- on the tv set. Now you'll be in service mode. On the remote press down arrow (not -channel) and you'll see up industry init. go there with ch- and press vol+ and enter. let the tv like that for few seconds and the tv will go green and hopefully industry init succsesfull will be on the screen. After that unplug the tv and replug it. Done!
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
