Panasonic TH-50PZ77U 50" Class Plasma HDTV Logo
Posted on Jul 29, 2008
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Mounting to TV Stand
I just purchased a new TV Stand with that you can mount the TV to. On this model is there anything specail I need to do to mount the TV to the stand. There are no instructions in the TV's manual on how to mount just in the manual for the TV Stand. I want to make sure that I can mount this TV to a stand before putting the stand together. Thanks
Anonymous
Level 2:
New Friend:
  • Expert 101 Answers
  • Posted on Dec 18, 2010
Anonymous
Expert
Level 2:
New Friend:
Answers
101
Questions
Helped
31575
Points
300
One make sure if you use other bolts supplyed that you make sure they do not go deeper than the original table stand bolts. make sure you get the screws you put in the wall in a stud or solid so it cant pull out and fall. other than that just follow the mfg instructions on the mount package.
Anthony Gonzales
Level 2:
Sergeant:
Champion:
  • Expert 267 Answers
  • Posted on Jul 27, 2009
Anthony Gonzales
Expert
Level 2:
Sergeant:
Champion:
Answers
267
Questions
Helped
85635
Points
536
THE STAND SHOULD BE ADJUSTABLE TO MOVE LEFT TO RIGHT AS WEL AS UP AND DOWN. ON THE BACK OF THE PANASONIC THERE ARE 4 OR 6 SCREW HOLES ABOUT 8- 10 INCHES FROM THE CENTER. IT USES 1/4 INCH SCREWS TREAD DIAMETER TO ATTACH THE PLASMA UNIT TO THE STAND.
  • Anthony Gonzales Jul 27, 2009
Anonymous
Level 2:
Sergeant:
Champion:
  • Expert 318 Answers
  • Posted on Mar 26, 2009
Anonymous
Expert
Level 2:
Sergeant:
Champion:
Answers
318
Questions
0
Helped
86329
Points
527
There are two types of stands, some are wall type which needs to be mounted using rawl bolts, nuts are suppose to hold a stand, some are ground stands which are suppose to be put on a flat surface in order to balance.
Remove stand from w4207 TV
Put tv on bed face down and look at the stand and locate and remove any and all screws holding stand to the flat screen set. Then after mounting the wall plate per instructions mount the tv to wall mounting.
Need stand/bracket for Dynex flat panel model DX-26LD150A11
with a brand like this you may have a hard time finding anything, You might look on MCM electronics if in North America as they sell about 50 different bases and mounting brackets that are universal ones.
I need a Panasonic TV TH-42PD25 base stand! I've searched ebay, no luck. This might sound dumb, but can I use base stands from any of the other Panasonic 42" models?
You maybe lucky, but make sure the mounting holes on the stand matches your TV.
Alternately you can use a wall mounting and these have mounting holes that suit most TVs.
Need a new stand for lcd television
If you are looking for a wall mounted TV stand these are available on the Internet.
There are several types of brackets avaible, use Google to search for wall mounting TV brackets.
Missing stand
You can get to find alternative mounting by visiting any hardware store. Please find some tips from the link below with which it can be mounted to be fixed on the table or rack.
http://www.regencyproducts.co.uk/
http://www.espares.co.uk/parts/tv-and-audio/lcd/plasma-brackets/p/1459
I need 1 leg of a stand for a Philips BDL 4231 TV. One of our legs snapped when moving the tv and we don't want to wall mount it. \r\nThanks, AOM
Electronics stores do not stock extra stands for TVs. Each TV comes with one stand and that stand goes with the TV.
If you contact Philips directly you may be able to purchase a stand on it's own, but this isn't likely if your TV is over a few years old.
Check ebay and see if anything is available in your area, if not, you may be limited to purchasing a hybrid stand to mount on or wall mounting.
2helpful
Cant find how to remove the stand on our newly purchased Soniq QSL323CT1 anywhere in the manual. We are trying to mount it on the wall.
1. Disconnect all cables.
2. Cover a level and stable surface with a thick and soft cloth.
3. Gently lay the TV, face down, onto the cloth. Make sure the Table-Top stand is hanging over the edge.
4. Rotate the cable holder 90 degrees, and pull it out completely.
5. Remove the screws (3 or 4 in rear next to cable holder, depending on which model wall-mount kit you have) being sure to hold the Table-Top-Stand firmly while removing the last screw.
6. Do not remove any other screws from the TV.
They also say not to remove the stand for any reason other than wall-mounting the TV. Their should be instructions with the wall-mount kit.
Hope this helps!
Thanks
Smith.
Stand
You should see at least 4 large phillips head or box headed screws tha hold the stand in place.
Top Panasonic Televison & Video Experts
 Grubhead
Grubhead
Grand Canyon Tech
Grand Canyon Tech
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
